Author Topic: intercooler tubes  (Read 9055 times)
txdohczc
intercooler tubes
« on: May 24, 2009, 03:31:35 AM »
i think i saw a thread a while back on ohmt about these things and i was browsing ebay when i came across them. i dont know if any of you would be interested in them but i figured i would post it up just in case
http://cgi.ebay.com/ebaymotors/Laminova-Intercooler-Core-for-Supercharger-Turbocharger_W0QQcmdZViewItemQQ_trkparmsZ66Q3a4Q7c65Q3a15Q7c39Q3a1Q7c240Q3a1318Q7c301Q3a0Q7c293Q3a1Q7c294Q3a200QQ_trksidZp3286Q2ec0Q2em14QQhashZitem27a85faf54QQitemZ170328567636QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
« Last Edit: May 24, 2009, 03:34:44 AM by txdohczc »
buk9tp
Re: intercooler tubes
« Reply #1 on: May 24, 2009, 03:33:59 AM »
49 bucks a piece is expensive.
i usually see em sell like 10 for 175
txdohczc
« Reply #2 on: May 24, 2009, 03:35:56 AM »
shit well fuck that then. i thought they were uausally 100 a piece i never looked them up or anything i just seen them on ebay and remembered a reading a thread about them
esi42
« Reply #3 on: May 24, 2009, 05:32:35 AM »
The admin of another forum I visit has them in his b16 jrsc setup:
« Reply #4 on: May 24, 2009, 10:12:12 AM »
The admin of another forum I visit waisted his time putting a jrsc setup on his b16 with a couple of those.
+1000000
« Reply #5 on: May 24, 2009, 03:23:57 PM »
looks like alot of air can go around those without any cooling effect, and if you could make it cool the charge well, it would make for one hell of a restriction
« Reply #6 on: May 24, 2009, 04:15:56 PM »
looks pretty restrictive
« Reply #7 on: May 24, 2009, 05:36:39 PM »
Looks hella restrictive. Look at the main in and out ports?
esi42
« Reply #8 on: May 25, 2009, 04:07:17 AM »
You guys are right.  That would be restrictive.
Im not sure if he totally knows whats up.  He was running a 12.8 afr up to and over 8000 on 8psi with resistor 7s at WOT.  Wouldnt post pics of the plugs or explain his reasoning for running that number.  He called it a "little lean".  Ive heard audible det from less boost on lower comp. engines.  I dont know what his timing maps looked like either.  I also wonder what his afr was in the high load low rpm areas.  I just know I wouldnt do that to my engine.
s300 at least.
crx-ecutioner313
« Reply #9 on: May 25, 2009, 06:33:56 AM »
2 smalll or give um 8 bucks 4 um then use um as a pipe for a escort
Kain
« Reply #10 on: May 25, 2009, 03:39:49 PM »
water flows through the tubes, and air flows over the tubes. the fains on the outside are for air to flow through.
the tubes arent restrictive at all.
« Reply #11 on: May 25, 2009, 03:42:38 PM »
Depends on how close they are to the manifold sides, but that also determines how efficent they will be.  Either way, its a shitty concept
« Reply #12 on: May 25, 2009, 03:45:15 PM »
Look like they would be best suited for an oil cooler in a radiator tank
« Last Edit: May 25, 2009, 03:46:48 PM by Conceptz-X »
QikEnuF
« Reply #13 on: June 01, 2009, 10:01:32 AM »
The moral of this thread is buk is a faggot.
txdohczc
« Reply #14 on: June 02, 2009, 02:26:16 AM »
i think we can all agree on that
« Reply #15 on: June 02, 2009, 07:34:11 AM »
Are we looking at the same pics, or not?
esi42
« Reply #16 on: June 04, 2009, 01:05:15 AM »
^^ I agree.  They block almost the whole runner.
« Reply #17 on: June 04, 2009, 01:13:29 AM »
if you look at how lht makes the plenums they raise them up higher then this guy, so there not as restricting.
but i would rather a a slightly restricted manifold then 200+ intake temps. but thats me.
esi42
« Reply #18 on: June 04, 2009, 01:20:18 AM »
He was at around 140 degrees.
« Reply #19 on: June 04, 2009, 04:55:39 PM »
    txdohczc   is a mod on the other site
txdohczc
« Reply #20 on: June 04, 2009, 07:36:12 PM »
honestly i just like tallking shit to all those h-t fags. it gives me some thing to do while looking through real webpages like redtube.com
« Reply #21 on: June 05, 2009, 09:08:50 AM »
What was that again, Benedict?
« Reply #22 on: June 05, 2009, 09:37:49 AM »
One down.  theres still another. ;)
