Author Topic: motorola 2.5 map help  (Read 10202 times)
MTZ
  • Webadmin
« on: May 24, 2009, 11:39:23 PM »
i need to know what wire is what in the harness so i can hook up my moto 2.5 but i dont have a voltmeter can some1 plz help...
91 crx d16a6
its called toering
Re: motorola 2.5 map help
« Reply #1 on: May 25, 2009, 12:02:45 AM »
would this help http://www.xenocron.com/install/DIY-Motorola-Map.htm  ;D
or this : http://www.xenocron.com/install/25map.htm ;D
I advance sorry for posting tec. from a sellout but it what I have to work with. ;D
MTZ
  • Webadmin
« Reply #2 on: May 25, 2009, 12:06:56 AM »
not really becuase i need a voltmeter that i dont have to know what cable is ground and which1 is 5v at the harness so i can hook up the 2.5... know what i mean?>
its called toering
MTZ
  • Webadmin
« Reply #3 on: May 25, 2009, 12:55:05 AM »
its called toering
« Reply #4 on: May 25, 2009, 01:06:23 AM »
A Helms manual is like a required textbook for a college class.  You are expected to possess one, and to use it.  I understand that some people are confused by, or do not understand how to read, a component datasheet and might need a pinout for the Motorola sensor (in which case you can check the index of useful threads, hint hint).  What I can not tolerate is refusal to use the excellence that is the factory service literature, complete with wiring diagrams, which we did you the favor of stickying in the Hybrid/Tech forum.
