Author Topic: Welfare Traction Bars---- thoughts  (Read 17287 times)
« on: May 26, 2009, 03:09:02 PM »
I want to build up some welfare Traction bars for the GRM $09 Car (1992 CX hatch)
This was my idea. heim joints are $25 Ea round these parts.  Old tie rods ends are Free and I had a weldZor
Front cross member would be 2x3 Steel Square tube (I have some) , or I will steal the 2" Sign post at the end of my block.. haven't decided.
Ties into the EG's Tow Hooks, I will just  heat and bend the tows into an L then weld the, to the cross member.
EF's are plentiful at my yard, so I would use their front trac bars and Nog rig to fit.
I also heard someone say S-10's have big ass front bars.
anyone see a prob with using Tie Rod ends?
Kind of a different take. This is how Mazda fags do it.
http://www.mazda3forums.com/index.php?topic=133353.0
weirtech
    • Weir Technologies Inc.
Re: Welfare Traction Bars---- thoughts
« Reply #1 on: May 26, 2009, 05:39:51 PM »
i'll sponsor the car, but i want something in writing about guaranteeing competing in the event with my stickers on it somewhere.  i've got a flange kit i could send you.
« Reply #2 on: May 26, 2009, 05:45:49 PM »
Damn baller. Wish I could get that kind of a hookup. I should be alright at the 1320 with only 7 pounds of boost on a 50 trim.
« Reply #3 on: May 26, 2009, 07:41:37 PM »
DONE!
« Reply #4 on: May 26, 2009, 07:45:10 PM »
Well played Aaron!
weirtech
« Reply #5 on: May 27, 2009, 09:08:45 AM »
DONE!
drop by the shop, pm me, email me or call me and we can work something out.
aaron
905-802-4703
« Reply #6 on: May 27, 2009, 02:42:45 PM »
aaron FTW!!!!!
« Reply #7 on: May 27, 2009, 03:30:37 PM »
Get the 1/2" heim's from speedway motors
http://www.speedwaymotors.com/Standard-LH-Male-Heim,7306.html
STANDARD LH MALE HEIM, 1/2" SHANK/HOLE
 left hand thread Item #: 1750305 $5.99
STANDARD RH MALE HEIM, 1/2" SHANK/HOLE
Item #: 1750105 $5.99
And for the tubes(swedge tubes) Make sure you figure out what lenght you need
http://www.speedwaymotors.com/Swedged-Steel-Tube-5-Inch-Thread,2090.html
« Reply #8 on: May 27, 2009, 07:30:48 PM »
How's that tie rod end gonna handle the sideways load?  All it has to do on a rack is hold the wheels steady, not take a pounding from the front-rear movement of the suspension while launching.
Not saying it wont work, but it might be a bit of a safety issue if one of those joints breaks, which they can do...
« Reply #9 on: June 07, 2009, 01:10:03 PM »
I like how the mazda people keep their pivot points in a straight line:
I also like that it's a tensile load, unlike like ours.  I actually put chromoly sleeves over my stock bars cause I bent one launching at some point last year.
