Author Topic: b18b auto swap  (Read 8967 times)
rudebwoy
b18b auto swap
« on: May 29, 2009, 07:33:56 PM »
I am picking up a 95 civic 4 door tomarow that has a blow head gasket. it has a sohc non vtec automatic, I plan to replace my green civic with it since its basically a hooptie now. anyways I happen to have a comple b18b motor an auto trans in my garage taking up space, I even have mounts with it, and engine harness.
what would it take to put this swap inside this car since they are both autos? would I get by with using the sohc ecu?
will sohc tranny cables work? what else do need to consider?
I don't wanna convert to manual even though I prefer a manual, and can easily transfer all the parts from the green coupe , I just don't have time nd patience for another project. I just want a daily reliable car.
rudebwoy
Re: b18b auto swap
« Reply #1 on: May 31, 2009, 03:35:26 PM »
so is this mofo easy to drop in or what? its not your tipical question so my search turns up no good results. I just wanna do a one for one swap remove sohc auto and install dohc auto.
will shifter cable or whatever autos use work the same with dohc ans the sohc?
I know its wierd but I have no other use for this ls motor so I wanna use it.
