Author Topic: boosting obd0 teg?  (Read 12161 times)
c0mpl3x
boosting obd0 teg?
« on: May 30, 2009, 01:04:45 PM »
this site has no info regarding it.  fuck the other sources of internet to answer this, rhmt is the knowledge pool everything pulls from anyways
whatchu niggers know?
Re: boosting obd0 teg?
« Reply #1 on: May 30, 2009, 02:14:34 PM »
huh??
my b20 teg is boosted on obd-0 TE
txdohczc
« Reply #2 on: May 30, 2009, 03:29:22 PM »
answer what you did not ask a question ???
« Reply #3 on: May 30, 2009, 04:20:25 PM »
church7 should get you started...
http://www.xenocron.com/bins/index.php?PHPSESSID=d48383b401bb853f38eb288446b55ca4&direction=0&order=&directory=TurboEdit
So you want to be spoonfed a howto on putting a turbo on your 90-91 integra?
« Last Edit: May 30, 2009, 04:22:18 PM by Foowee »
« Reply #4 on: May 30, 2009, 04:42:01 PM »
ha...
church7 bin blew my first b20.  hahah
« Reply #5 on: May 30, 2009, 05:25:05 PM »
nevermind then...
« Reply #6 on: May 31, 2009, 10:45:05 AM »
It's like any other car. You fit a couple of pipe together and you have a turbo kit.
-450cc with resistor box (use a dremel to oversize the intake o-ring)
-Intercooler: follow the same path than a CAI for the intake side and use the hole on the side of the windshield washer liquid or just make your own hole where you want it. (can make a good job with ebay kit...)
-Manifold: use what you want, but be sure the turbo isnt too low or it will hit the crossmember.
-OBD0 ECU: Place the connector on your left and the chip to remove is the third from bottom to top on right (near the case on the right)
-BOV: use a T to connect the bov inlet on any vac source on the intake manifold
-Wastegate: if you have a outlet on the turbo use it, otherwise use another vac source from the intake manifold. ( use green spring 7.5psi and if you want more install a boost controller)
-clutch: change it now, you will blow it anyway.
picture ressource: http://picasaweb.google.com/fp.bibi/Turbosetup#
Don't put the turbo or wastegate too near of the rad like I did, big mistake LOL
Good luck.
« Reply #7 on: May 31, 2009, 12:23:59 PM »
why is this thread getting replies? this belongs on ohmt  ::)
BoostForLife
« Reply #8 on: May 31, 2009, 02:54:23 PM »
If you want more out of your teg, raise the boost and get it tuned.
Take the whole exhaust off but the downpipe.
/thread
BoostForLife
« Reply #9 on: June 01, 2009, 03:45:27 AM »
same as for OBD1, except differnt ecu/software to tune.
« Reply #10 on: June 01, 2009, 03:59:33 AM »
obd0 pr4 and  turboedit.
its easier then obd1 because the ecu simply needs a chip desoldered and socket soldered in place. you wont need to wire a resistor box because it already has one.
BoostForLife
« Reply #11 on: June 01, 2009, 04:03:05 AM »
He never said he is running low impedance injectors, even though most that support boost are.
« Reply #12 on: June 01, 2009, 08:44:43 AM »
I had a 90 teg and I don't think  there was a resistor box into it.
91 have a resistor box for sure.
BoostForLife
« Reply #13 on: June 02, 2009, 01:07:50 PM »
Map sensor reads the same pressure as OBD1 because if you obd1 conversion no map sensors need to be changed. They are different externally and are mounted on the firewall instead of on the TB. Just use the stock Honda Map sensor setting in turboedit.
All obd0 hondas/acura run resistor boxes, some obd1 hondas as well. (accords/preludes)
« Last Edit: June 02, 2009, 01:10:16 PM by BoostForLife »
