Pages: 1 2 [3] 4   Go Down
Author Topic: Orange Chicken ZC Del Sol Build thread. Rippers added.  (Read 141943 times)
Re: Orange Chicken ZC Del Sol Build thread. Rippers added.
« Reply #60 on: June 02, 2009, 12:18:34 AM »
I don't think we're talking about the same thing?  What i was saying is tune for 12:1, with wheelspin you get 13:1.  It hurts nothing, and if you hook you get 12:1.
OK I got you JD. I was thinking tune it to 12.8 and all I could think is it would hook and make a massive load and det like a mofo!
« Reply #61 on: June 02, 2009, 12:20:28 AM »
Ok, so that is my issue.  I have 3rd gear tuned and it hits mid to high 11s just fine.  When I am in second it is high 12s with traction.
What?
Im lost....lol
« Reply #62 on: June 02, 2009, 12:24:16 AM »
The turbo takes a minute to spool :)  going up a hill in second until about 5-5500 no traction issues, after that  :evil:  I will have to go get a log danmit!
BoostForLife
« Reply #63 on: June 02, 2009, 12:48:43 AM »
But the one time your tires hook up, it could end bad.  :'(
I would shoot for the lower 12's for a street car. But if you are the only one that is gona drive it I wouldnt worry about it to much. Its the 1 time you let someone else drive it and they go up a hill in 3rd gear at 25mph and that bitch is pinging all the way up the hill.
I don't let people drive my car period.
BoostForLife
« Reply #64 on: June 02, 2009, 03:07:25 PM »
how's the spool now?
My ZC didn't make it home yesterday. Started knocking rattling so I pulled over. Just brought it home right now. Oil on spark plug #2, im thinking a broken/bent valve. I might not need the dizzy after all but pretty sure will need the timing belt cover.
Do you have any spare ZC block/head?
i have both, with pistons to match
I'm going to take the head off this week and see what's up, it doesn't sound like a bearing.
Vadim
« Reply #65 on: June 02, 2009, 05:44:45 PM »
Adgast your valves...
BoostForLife
« Reply #66 on: June 02, 2009, 05:58:10 PM »
valves  were adjusted the night before dyno day
BTW: this is not the thread to figure my problem out.
« Reply #67 on: June 02, 2009, 07:56:27 PM »
Yeah bitches, GTFO  ;D
« Reply #68 on: June 05, 2009, 08:11:40 PM »
Went back to the Dyno today.  Did 3 pulls and now it is 10hp less.  Got the Map sensor fixed up but now the ignition is breaking up after 5k.  :(  Looks like I need to fix that now.  Also  turns out my water pump is done.  Found a big nasty puddle when I backed it off the dyno.
« Reply #69 on: June 05, 2009, 08:17:17 PM »
Oil on plugs aren't bent valves.  You don't need a thread to figure out what's wrong with your motor, you need common sense.
« Reply #70 on: June 05, 2009, 10:41:14 PM »
I wouldn't worry too much about the difference in numbers, especially since it's a different dyno. Does the car feel any different? Did you make any changes to the map on the dyno?
« Reply #71 on: June 05, 2009, 11:00:26 PM »
I pulled 2 degrees of timing and it lost about 5hp.  The ignition did break up more when I did it too but I heard no det with my det cans.  I think I just have to find out why it is breaking up.
« Reply #72 on: March 16, 2010, 12:13:09 PM »
Finally did some more work on this piece of shit trying to get it ready for the dyno day.  Had a huge crack in the manifold the size of BDVTs Mom's Snatch that had to get welded up.  Wastegate had a hole in the diaphram and I didn't want tokeep waiting for the wastegate I got from MarcJ so I went ahead and put a new chinese wastegate on it for now.  Also built an exhaust for it finally.  All 3" SS with a Dynomax Round muffler in the middle instead of a resonator and a Borla at the back.
This thing is by far the quietest 3" exhaust I have ever heard.  Got all that shit done and took it for a ripper this morning and everything seems good.  Need to do a few more things like clean up the interior as it leaked al over this winter in it and it is all nasty.
« Last Edit: March 16, 2010, 12:20:12 PM by malichite »
« Reply #73 on: March 16, 2010, 12:34:05 PM »
im liking that turndown!
« Reply #74 on: March 16, 2010, 12:53:07 PM »
Another shot of it.  I like the setup so far.  Sounds great.  I will try to get some video tonight or tomorrow.  Need to get a battery for this piece of shit first.  Tired of jumping it.
« Reply #75 on: March 16, 2010, 01:22:17 PM »
Turndowns are hawt!! To bad mine is like a turnaround instead.....lol Just need to trim it some to make it look better. I need to bring my pos down so we can redo the axle back on it. Yours turned out good man.
« Reply #76 on: March 16, 2010, 05:00:02 PM »
I thought this car got traded for a coupe?
« Reply #77 on: March 16, 2010, 05:11:05 PM »
trade never went through.
« Reply #78 on: March 16, 2010, 09:04:35 PM »
Holy fuck its about time you work on this slut. Seems it came together nicely.
« Reply #79 on: March 17, 2010, 10:06:53 PM »
No good audio of it idling but here are a few rippers I did today :p  Need to rebuild my tranny.  3rd is almost impossible to get into.
ZC Powered Del Sol 13psi 2
ZC Powered Del Sol 13psi 1
« Reply #80 on: March 18, 2010, 10:49:51 AM »
cranked the boost up more this morning.  Up to 18PSI.  Car is just useless :evil:  No traction at all :p  Got to get a battery for it today and some tabs then time to max out these injectors.
« Reply #81 on: March 18, 2010, 02:25:53 PM »
I want to race you now.....  :evil:
Im wondering how they would do....lol
Maybe in a few weeks When i come down we could go do some freeway rippers.
You better get some crank case ventilation on that bitch! Like yesterday!
« Reply #82 on: March 18, 2010, 04:03:05 PM »
Got material at home to build a snatch can.  Will be done this weekend  :noel:
« Reply #83 on: March 18, 2010, 05:02:48 PM »
Best not to be boosting that much with no way for the crank case to get rid of it. Dont be dumb man. Hit me up, I got a  littel trick to tell u about the can :noel:
« Reply #84 on: March 19, 2010, 01:38:48 PM »
Did you get the catch can done last night nig?
« Reply #85 on: March 19, 2010, 03:02:40 PM »
Negative.  Got to Belfair Hoes to late.  Going to try to get some fittings today. :mexi:
« Reply #86 on: March 19, 2010, 04:23:10 PM »
You nig, Ive got 2 -10 by 1/2npt if you want to come and get them.
« Reply #87 on: March 22, 2010, 11:20:34 PM »
Well, before I can get a catch can on it, I need to make some room.   Time to move the battery.  That was todays mission.  I built a new battery tray from some aluminum angle.  I mounted up 3/4" to make room for the new floor floor I want to put in later.  I still need to run the power cable to the back and I need to make a new battery tie down that isn't all nasty. My aluminum welds are not up to where I would like them yet but they hold.   Anyways, as usual, here are the pictures.
« Reply #88 on: March 22, 2010, 11:44:45 PM »
pimp, what about Putting it inside a ammo can? I know that it wont pass tech at the track if its not in a sealed baox, and you need a cutoff switch.
« Reply #89 on: March 22, 2010, 11:49:03 PM »
Didn't think the sealed box matters sense it is in the trunk and not in the cabin.  I will be puttting a cut off in also.
Pages: 1 2 [3] 4   Go Up
