Author Topic: Removing fluting from glass headlights?  (Read 14590 times)
« on: June 13, 2009, 03:52:25 AM »
So I was pulled over for headlight being out today and instead of buying new bulbs I'd like to go ahead and do a proper HID retrofit.
What can I use to remove the fluting from the glass lenses?  I'd rather not use ghetto plastic ebay headlights or the plastic clear lenses since they like to turn yellow.  Would rather remove some of the fluting where the projector would be and keep the glass.
Any ideas?
Re: Removing fluting from glass headlights?
« Reply #1 on: June 13, 2009, 04:39:52 AM »
dude trust me its not worth the effort, i spend about 30 min sanding with a power sander and i didnt even make a dent in the fluted. i tried very high grit metal sandpaper >15k and some like 200 grit and it doesnt make any difference.
i am making my own lenses out of lexane using a plaster mold and a female ring
here is one that is almost 100%. the plastic is specifically meant to not yellow in the sun, check the label.
mold
some failed attempts
« Last Edit: June 13, 2009, 04:41:36 AM by t_cel_t »
« Reply #2 on: June 13, 2009, 05:54:48 AM »
Damn, I was hoping there was some sort of rotary tool I could use to grind the shit off.  I just need a circle.  Lexan looks like a pain in the ass too.
realAgentMurdoc
« Reply #3 on: June 13, 2009, 06:48:05 AM »
just retro the projectors anyways.  you'll still get a nice cutoff and the stray light is pretty minimal.... usually.
90boostdaccord
« Reply #4 on: June 13, 2009, 07:58:12 AM »
^^^^^listen to the man
« Reply #5 on: June 13, 2009, 08:32:17 AM »
mold
Do you just lay the lexan on the mould and heat the bitch up?
Yeah, I guess it wouldn't hurt to see how bad it'll fuck it up first.  If it's too bad I'll go another route, just don't want to blind motherfuckers because I know it pisses me off
« Reply #6 on: June 13, 2009, 08:42:35 AM »
no i made a fram out of wood, screw the plastic to the frame, heat it up in oven, pull it out and put it over the mold, push down with the female cutout.
check this out
http://www.hidplanet.com/forums/viewtopic.php?t=31577&highlight=
« Reply #7 on: June 13, 2009, 09:02:32 AM »
check this out
You doing CRX lenses?
If you ever perfect it, I'd gladly pay you for some lenses or the cutout (I don't have a nigsaw).  :P
His turned out really well, and it looks like you're making progress.
« Reply #8 on: June 13, 2009, 02:01:21 PM »
Get some mad tyte chromes housins yo
« Reply #9 on: June 13, 2009, 05:14:38 PM »
where is the vacuum connection???
« Reply #10 on: June 13, 2009, 05:19:35 PM »
rhmt, bone
brue force > vacuum assistance
« Reply #11 on: June 13, 2009, 05:43:42 PM »
yeah i built a vacume box but it was total fail, pressing/stretching the lenses is way easier
« Reply #12 on: June 13, 2009, 11:26:59 PM »
I hate passing faggots with 15+ year old hondas and mAd TyTe jDm projectors blinding me and everyone with sweet blue light.
Hit the lenses with 1000K or 2000k then clear them and drop the 40 bucks on the silver star Silvana.  Done, i see everything and dont blind anyone.
« Reply #13 on: June 14, 2009, 07:31:06 AM »
if they are blinding you they are not projectors, all they did was install a rebased hid bulb
« Reply #14 on: June 14, 2009, 12:07:59 PM »
i think thats what he is getting at.... how dumb it is.
« Reply #15 on: June 15, 2009, 08:04:49 PM »
You have the wrong person, sir.
If I'm going to go through the trouble of doing something, I'll do it right.
IE - actual quality projectors, bulbs, and ballasts.  The ricers you're bitching about are the ones that didn't do it correctly.
I have Silverstars, they help, but they still aren't that great, not to mention they're expensive for a bulb and mine just burned out after a little over a year of use.  I live out where there's a lot of animals/backroads, and extra lighting would be fucking nice.  OEM projectors/ballasts have gotten a bit cheaper and I think they're in a "reasonable" price range.
« Reply #16 on: June 24, 2009, 12:14:19 PM »
Yeah i knew if you were doing this id be done right.  iwas talking bout the damn ricers and their HIDS in their stockers.
Half the time Projectors in Stock housings looks really good.
Damn my bad for the week late bump there.
« Reply #17 on: June 25, 2009, 03:56:32 AM »
Never had silverstars, but rocked Cuzo bulbs in my EF and they worked pretty damn good
« Reply #18 on: June 25, 2009, 08:17:33 AM »
Im rocking Silverstars right now and they are awesome.  The bulbs that is.
Funny thing my damn plastic headlights are ok but my Stock fogs are glass and they are almost brighter than my headlights.
« Reply #19 on: June 26, 2009, 01:57:48 AM »
Silverstars are great, but their lifespan is rated at 1/10th of the regular bulb, no joke. However they're not expensive if you buy at the right place, mine were $15 per pair at amazon w/free shipping.
I'd just recommend FX35's into regular housings if you can, or any hi/low combo, if you have the space. Right now I have an air filter & boost solenoid where the projector would stick out of the housing. :-\
