Author Topic: 84mm headhasket  (Read 11238 times)
rudebwoy
84mm headhasket
« on: June 15, 2009, 07:22:34 PM »
84mm headgasket in 84.5mm
is it safe?
civiceggturbo
Re: 84mm headhasket
« Reply #1 on: June 15, 2009, 07:38:17 PM »
 honda oem sized head gaskets are made to be able to work with +1mm over sized bores, I currently run a 81.5mm bore ls with a stock ls headgasket.
rudebwoy
Re: 84mm headhasket
« Reply #2 on: June 16, 2009, 01:59:50 PM »
I hope you are correct, I currently need a head gasket, my bore is 84.5mm I have a new b20 honda genuine headgasket (84mm). and don't feel like spending another $100 for a golden eagle bore over oem unit, or even wait for it to get here.
Re: 84mm headhasket
« Reply #3 on: June 16, 2009, 02:03:36 PM »
You sure that goes for all Honda hg's? The hg in the f22a measures 85.5mm and the bore is 85mm.
civiceggturbo
Re: 84mm headhasket
« Reply #4 on: June 16, 2009, 07:54:59 PM »
i wish i would have measured my d16, to know what it actually measured, same thing as my ls .5mm over with stock headgasket
i know b18s and d16s stock head gaskets work, how are you measuring it calipers? scale?
just make sure the headgasket does not overhang the cylinder
rudebwoy
Re: 84mm headhasket
« Reply #5 on: June 17, 2009, 06:24:54 AM »
it does not overhang, but its an exact fit
