Author Topic: Piston Identification  (Read 13831 times)
Rosario4124
  • HATE HATE HATE
« on: June 17, 2009, 07:01:37 AM »
can't find this shit so i figure i leave it up to the interweb gurus around were its a forged piston and the only thing i can see is the  # 292105 on the bottom of the piston.
Re: Piston Identification
« Reply #1 on: June 17, 2009, 05:05:03 PM »
What year ford is it from?
« Reply #2 on: June 17, 2009, 05:51:11 PM »
Any part # starting with 29 is GM
Rosario4124
  • HATE HATE HATE
« Reply #3 on: June 17, 2009, 07:06:23 PM »
maybe i have the numbers fucked up  ???
racingtiger
« Reply #4 on: June 17, 2009, 07:07:30 PM »
Go to pick-n-pull with one of the pistons and just start pulling apart blocks and test fitting until you find one that works.  That's probably the easiest and fastest way.
« Reply #5 on: June 17, 2009, 07:58:32 PM »
pics?
bouncinofftherevlimiter
« Reply #6 on: June 17, 2009, 10:07:11 PM »
pics?
also relevent information like diameter, compression height, pin bore, floating or pressed pin.
Any of above information will help greatly
also where did you find it?
No longer own a turbo car...
HX35 18lb 486hp/391tq
« Reply #7 on: June 17, 2009, 10:09:34 PM »
Easy and Fast, I doubt it
Not to mention the pick your part people dont want all thier shit opened up to rust and go to hell so you can find out what something came from.
That Guy
  • Fast and danger
« Reply #8 on: June 18, 2009, 06:55:06 AM »
lol
« Reply #9 on: June 18, 2009, 08:24:12 AM »
Its a z6 that was had for cheap!  We dropped the oil pan to do the return and there was some I beams just looking at us like "Hey guys"
We might pull the head today......
I think they are CDM/Egay rods and pistons..........
« Reply #10 on: June 18, 2009, 03:50:57 PM »
Ha.  When I pulled the valve cover to adjust the valves on the crx, I noticed the arp head studs. lol, always a bonus.
« Reply #11 on: June 18, 2009, 06:12:45 PM »
I think JE/SRP uses a 6 digit code similar to that.
« Reply #12 on: June 18, 2009, 10:11:00 PM »
SRP D16 start with 149xxx
