Author Topic: blown headgasket between the cyls?  (Read 6137 times)
c0mpl3x
« on: June 17, 2009, 10:36:16 PM »
did headgaskets on a v8 a while back, what causes them to blow between cyls? cam/dizzy timing out of whack?
the heads/block were below spec for warpage, too
Re: blown headgasket between the cyls?
« Reply #1 on: June 17, 2009, 10:51:52 PM »
didn't retorque after 500 miles.
Random Hero
« Reply #2 on: June 17, 2009, 10:57:49 PM »
Because you have pressure on either side of the headgasket slowly wiggling it back and forth. Mazda b2000's are known for this to.
« Reply #3 on: June 18, 2009, 02:12:14 AM »
in for updates
« Reply #4 on: June 18, 2009, 07:07:16 PM »
Check the block and head for flatness.  If they ran it blown for a while, the combustion gasses shooting across the gap will actually cut a groove into the head and block.  Also, improper torque, you did lube the threads and hex end didn't you?
« Reply #5 on: June 18, 2009, 11:41:18 PM »
I've done lots of head gaskets like that, even with flat head/blocks.
jarebear667
« Reply #6 on: June 19, 2009, 01:03:18 PM »
i have had it happen to a few of my h22 gaskets oem honda too. i think it was bad/reused arp studs and poor torqueing on my side.  the surfaces were true also.    part of the reason i said fuck it and tore it apart.
midwest HMT!
slaminsam
« Reply #7 on: June 19, 2009, 02:15:52 PM »
I have seen a few mustangs blow in between cylinders but they were also boosted.... Some while trying to dial in with a btm and fmu... They would lean out with a little to much timing and blow between cylinders...
« Reply #8 on: June 19, 2009, 02:22:58 PM »
Detonation + path of least resistance, Jon.
« Reply #9 on: June 19, 2009, 02:53:46 PM »
Not that it means much for you guys, but this seems to be the path of least resistance in o-ringed and fire ringed Cummins motors EDIT: and the 3rd gen CR trucks that run factory MLS gaskets. Stock fiber HG's seem to be more prone to blowing out the side under the exhaust manifold.
« Last Edit: June 19, 2009, 02:55:54 PM by dvst8r »
