Author Topic: Can this be saved or not? Tranny ?  (Read 9998 times)
« on: June 17, 2009, 11:13:59 PM »
ok long story short got tranny on ebay, case was broke upon arrival, got money back and got to keep the tranny. Okay so here is what i first found when I got it.
Well last week got bored and opened it up to find this
This thing is fucked up and so i check out the case
so is the case even saveable or not? The gear sets don't look bad but obviously diff is shot. Just curious what if any could be salvaged from this mess? Wtf did this kid to to the tranny to do that?
« Last Edit: June 18, 2009, 12:51:38 AM by jdmhatchracer94 »
Re: Can this be saved or not? Tranny ?
« Reply #1 on: June 18, 2009, 03:16:05 AM »
Wheelhop is a bitch. Broke the retaining pin for the diff pin.
Case and diff carrier are junk, save the speedo ring gear and all gearsets after close inspection.
CLEAN EVERYTHING on the gearstacks. This means full takedown. Those little pieces of alum get everywhere.
BTW, that tranny was making a racket when last driven.
That Guy
  • Fast and danger
« Reply #2 on: June 18, 2009, 06:52:46 AM »
another ebay scammer? at least you got your money back and got to keep it
« Reply #3 on: June 18, 2009, 12:35:52 PM »
yeah I even sent him the tranny back but he never picked it up day after I got the refund the tranny showed back up.
Damn case is toast then. Honestly I don't even know what this tranny is as far as ls,gsr, I dunno
« Reply #4 on: June 18, 2009, 04:14:46 PM »
start counting teeth, might be a LS, have a nice 5th gear for cruising
« Reply #5 on: June 18, 2009, 04:25:10 PM »
count teeth on what gear?
BoostForLife
« Reply #6 on: June 18, 2009, 04:40:46 PM »
I believe the final drive.
The second chart/table on this website should help you out a little bit with identification.
http://www.ff-squad.com/tech/temp/Bgears.htm
« Reply #7 on: June 18, 2009, 07:07:04 PM »
good info thanks I will check it out when I get home.
« Reply #8 on: June 18, 2009, 10:05:38 PM »
all 12, no need to count the three for reverse.
