Pages: [1] 2 3   Go Down
Author Topic: diy low comp pistons  (Read 34113 times)
turbostd
Re: diy low comp pistons
« Reply #1 on: June 18, 2009, 10:43:43 PM »
lol
« Reply #2 on: June 18, 2009, 10:49:38 PM »
thats the sort of shit i would do
« Reply #3 on: June 18, 2009, 11:19:45 PM »
I bought a $700 lathe so i could make that not look completely stupid.
« Reply #4 on: June 18, 2009, 11:24:27 PM »
I think with a die grinder and a little time it could be made to work, just have to get rid of a few sharp edges. Then get a syringe and some water and make sure there all close, good to go.  O0
« Reply #5 on: June 18, 2009, 11:26:12 PM »
He just didnt finish the job, I would rock them anytime.
« Reply #6 on: June 18, 2009, 11:35:52 PM »
Funny part is he sold the engine. Would have been funny if they had installed it and try to start it.
« Reply #7 on: June 18, 2009, 11:38:08 PM »
thats acually very common with some types of engine building, diesels, porsche's ect
« Reply #8 on: June 18, 2009, 11:42:05 PM »
That can only be the work of a stupid ass puerto rican. THey're always trying to do something on the cheap but always end up fucking shit up.
« Reply #9 on: June 19, 2009, 01:29:13 AM »
Vitaras also have a very thick crown.  With how the 1.7 stroker setups bump CR up to a horrible 9:1 CR, lathing a piston down is one of the ways in which we've discussed lowering CR back down to a heavenly 7.5:1.
bryantaylor
« Reply #10 on: June 19, 2009, 02:45:46 AM »
we talked a guy into JB welding his pistons to raise the compression.  the fake magazine article is awesome.
http://forum.miata.net/vb/showthread.php?t=308510
90 miata - t3 and megasquirt
95 mark VIII
06 GSX-R 600
 i changed my sig as per Robb
buk9tp
« Reply #11 on: June 19, 2009, 02:51:58 AM »
now thats fucked up
Adam Lofton
« Reply #12 on: June 19, 2009, 05:39:02 AM »
 ::) I've been doing that for years with a band-saw.
« Reply #13 on: June 19, 2009, 05:45:22 AM »
now thats fucked up
ahh holy fuck thats funny, did he ever run it
« Reply #14 on: June 19, 2009, 08:52:18 AM »
Local guy made some pistons out of blanks on the grinder. Ended up being 14.5:1 compression and in a 351w stock bore and svo heads made 612 wheel Hp.  Trips the 60' lights on the rear tires in a mustang cobra II.
« Reply #15 on: June 19, 2009, 10:18:21 AM »
Now that is hard core.
bryantaylor
« Reply #16 on: June 19, 2009, 08:14:21 PM »
now thats fucked up
not yet
95 mark VIII
06 GSX-R 600
nels2825
« Reply #17 on: June 20, 2009, 01:39:09 AM »
homemade piston would be the shit
E-b0la
« Reply #18 on: June 20, 2009, 06:38:15 PM »
interesting. would you be just facing the piston off and making a flat top out of it to lower compression? Or maybe put a slight dish on the piston?
« Reply #19 on: June 20, 2009, 06:57:49 PM »
need a Vitara to cut in half before I can comment
« Reply #20 on: June 20, 2009, 07:03:34 PM »
And what rods are you thinking on using?
If I recall correctly, the D17 BE width is quite narrow.
Crowers maybe, but that seems a bit too spendy for a project that is probably based off of mostly free parts.
buk9tp
« Reply #21 on: June 20, 2009, 08:21:39 PM »
ls rod swap?
« Reply #22 on: June 20, 2009, 10:11:42 PM »
Already bought generic forgings from marcj; they hit the door last Monday and they were milled by Thursday.
« Reply #23 on: June 20, 2009, 10:17:29 PM »
OIC.
 :P
« Reply #24 on: June 21, 2009, 01:10:09 AM »
I do this to DI diesel pistons a lot, which is fun because the combustion chamber is eccentric to the O.D.
By the way its called "turning", not "lathing".
« Reply #25 on: June 21, 2009, 01:15:48 AM »
Oh shit I can't wait to see JD's response. Never seen him get called out on anything.
« Reply #26 on: June 21, 2009, 01:33:43 AM »
Turning is every bit as inaccurate as lathing.  It's a garbage baby word meant to communicate with simpletons. The actual machining operations possible on a lathe are cutting, sanding, knurling, drilling, or deformation.  The procedure being discussed, if it's called anything, is cutting.
ok??
Adam Lofton
« Reply #27 on: June 21, 2009, 01:35:53 AM »
^^^ Uncontrollable WIN
« Reply #28 on: June 21, 2009, 01:36:50 AM »
ok??
My hero  :-*
bryantaylor
« Reply #29 on: June 21, 2009, 02:32:09 PM »
ok??
i love you JD
95 mark VIII
06 GSX-R 600
Pages: [1] 2 3   Go Up
