Author Topic: RHMT Fan  (Read 8346 times)
RHMT Fan
« on: June 29, 2009, 11:20:36 PM »
You will need:
One Katrina flooded HVAC inside units to remove a blower fan from. Rinse thoroughly.
Some old 2x4's previously used for concrete forms
Long ass wire that your neighbor gave you when he sold you a Miller 130 for $250.00  :noel:
Some bolts and nails you have laying around.
Total: $0.00
This is the best 220V free fan I ever had. 700 CFM blower. I bought a water misting kit I'm gonna add to it that will drop the temp of the air 15-20*F. WIll install that and see how it does when the kit gets here.
Re: RHMT Fan
« Reply #1 on: June 30, 2009, 05:18:45 AM »
put at least a sheet of chicken wire on the outlet of that, couple hundred rpms plus a sheer point equals little kiddy sized amputations
Re: RHMT Fan
« Reply #2 on: June 30, 2009, 05:25:26 AM »
chicken wire the inlet, the outlet won't matter after that!
Re: RHMT Fan
« Reply #3 on: June 30, 2009, 06:43:23 AM »
you could still stick your hand in there
Re: RHMT Fan
« Reply #4 on: June 30, 2009, 09:34:32 AM »
Don't chicken wire it.. Throw shit into it while it's running.. like marbles.
E-b0la
Re: RHMT Fan
« Reply #5 on: June 30, 2009, 09:09:07 PM »
Hell throw small children in there.
1slow91hf
Re: RHMT Fan
« Reply #6 on: July 01, 2009, 12:49:12 AM »
ill have to post pics of our shop fan made from a rolling display cart and a double squirrel cage  :noel:
Re: RHMT Fan
« Reply #7 on: July 01, 2009, 03:05:35 AM »
ballin
finish it already
d-rail
Re: RHMT Fan
« Reply #8 on: July 02, 2009, 04:30:04 AM »
ballin
finish it already
eville140 had one in his shop. Standing next to it makes you nervous because of the vacuum it produces. Def needs a protector if any kids or drunk people are around.
Re: RHMT Fan
« Reply #9 on: July 02, 2009, 12:18:41 PM »
Got the water misting kit. It sprays a fine mist, but it's not fine enough. So it doesn't all evaporate. Gonna make a plastic tank out of some 4" PVC (rated at 200 something PSI) and use it for a tank to hold water, then hook a compressor to it to get the pressure up higher that faucet water (~35 PSIG). Hopefully this will help.
Re: RHMT Fan
« Reply #10 on: July 02, 2009, 12:51:00 PM »
With water misting wouldn't that be considered a swamp cooler? ;D
Re: RHMT Fan
« Reply #11 on: July 02, 2009, 07:11:35 PM »
This is a RHMT swamp cooler... hahah
