Author Topic: does anyone have the diagram for the NOGGLE SWITCH  (Read 7993 times)
ShoofIsLudin
« on: July 02, 2009, 06:03:30 PM »
On the old site, there was a write up of how to make a noggle switch?   This is something that i've put off on starting to make.
It just seems like a great idea for 2 boost settings, and its exactly what i'd like for my DD when it finally comes together
Parts needed was:
-an EVAP purge solenoid?  or some other OEM solenoid that can be easily swiped from a j-yard
-relay
-wire and connectors
-MBC
-vac lines
-WHAT ELSE was there, and does anyone have a diagram?
Can it be simplified?
cbustuner
Re: does anyone have the diagram for the NOGGLE SWITCH
« Reply #1 on: July 03, 2009, 12:10:34 PM »
http://www.tamparacing.com/forums/mitsubishi-tech/470904-diy-2-stage-boost-controller.html
diagram on that page. Ignore the ground on the switch unless your using  a switch with a light on it.
