Author Topic: Megasquirt Help!!  (Read 8816 times)
kamilk69
Megasquirt Help!!
« on: July 13, 2009, 09:06:47 PM »
anyone good with megasquirt, im trying to get it to run in my focus. so far i got the injectors to pulse, iat working and coolant temp to work. but now the fucking car work produce a spark.
my setup uses a vr sensor and edis-4, ive switched my polarity and vr sensor and i still get fuck all.
the way i have it set up,
vr sensor - edis with 2 wire sheilded. then edis produce a base timing without any help from megasquirt and fire the coil but still nothing.
BigGameHit
  • grassroots drifter
    • My Racing profile
Re: Megasquirt Help!!
« Reply #1 on: July 14, 2009, 02:14:47 AM »
what version of MS is it???
TTC
« Reply #2 on: August 06, 2009, 12:25:39 AM »
IIRC the EDIS unit should spark without even being hooked up to the MS. When i tested mine, i just benched the edis unit with the VR sensor. Try switching the VR wires, its a common mistake.  It should spark regardless of MS, it will just run at base EDIS timing with I think is 10 deg.  double check your wiring something is up.
Also, a heads up, put the capacitor on the coil and run a stereo voltage filter on the power wire going to the MS.  I found it cleaned up all sorts of fuckery.
« Reply #3 on: August 11, 2009, 07:58:03 PM »
Do you get an RPM reading in megatune?
