What would you run for engine management
Megasquirt
Microtech
Convert to Honda
Fuck it, run an FMU
Its an escort, who gives a fuck
Buy another honda
Sinisters never had a turbo car, why should anyone?
Author Topic: ECU for 1.8 BP  (Read 9719 times)
carkrazed
ECU for 1.8 BP
« on: July 19, 2009, 12:18:00 PM »
K bitches, I'm almost done fabbin shit for my build and i'm on the fence about what to run for engine management. Spread your knowledgabilities.
Motor is a 1.8 mazda Bp
Car is an escort gt
Build thread is here - I'll be updating that shit as i've got alot more done than is shown.
http://www.realhomemadeturbo.com/forum/index.php?topic=255.0
Re: ECU for 1.8 BP
« Reply #1 on: July 19, 2009, 09:15:30 PM »
Megasquirt on a Miata (derivative) is a no brainer.
I'd put a Honda distributor on it because I have all that shit laying around and the Megasquirt would cost me money.  Do you?
FYI until Microtech cares to support a battery compensation table it is a failure.
Re: ECU for 1.8 BP
« Reply #2 on: July 19, 2009, 09:42:10 PM »
I like MS on every Miata I tune.
I dislike it on ever distributor 6+ cylinder car I tune.  I understand there's a lot more flavors out there and some stuff with correct dwell control now, so most of what I bitched about has been addressed *if you get the right setup*.  Since I ASSume you're going to be running a cam position sensor and coilpack in wasted spark mode, you can disregard me and just pick up any Miata-approved MS setup.
Re: ECU for 1.8 BP
« Reply #3 on: July 19, 2009, 09:50:43 PM »
You should be fine since it's a 4 cylinder.  The older MS1 with the spark add ons had some shitty canned pull down coil dwell tables that just caused some 6-8 cylinder vehicles to misfire after a certain RPM, or not catch when cranking but drive great if you rolled them off.  I don't think those problems will apply to you, there's a lot more time to charge the coil on a distributored four cylinder engine.
Re: ECU for 1.8 BP
« Reply #4 on: July 19, 2009, 10:00:19 PM »
I can.  How far away are you from WNC?
