Author Topic: I keep killing tires.  (Read 9177 times)
« on: July 31, 2009, 09:50:40 AM »
Third in a month, the last two in under 18 hours.  I feel like I'm starring in Final Destination.
I hopped in this damn thing and drove it for all of fifteen minutes, thought a weight had fallen off the wheel as it had a mild vibration that varied/went away at various speeds, smelled hot rubber and heard the tire hissing when I got out of it.  I sure as hell didn't think the belt had broken in multiple places and was trying to exit stage left as individual strands.   ???
Re: I keep killing tires.
« Reply #1 on: July 31, 2009, 10:32:02 AM »
Damn, you have a hex on you or something?
« Reply #2 on: July 31, 2009, 10:46:06 AM »
i'm not surprised, look at that fucking dry rot in the tread. buy some decent tires, sir.
« Reply #3 on: July 31, 2009, 10:50:23 AM »
Not my cars.
The EP3 cracked a 19" in two places, the 35 series sidewalls are so stiff the tire looked full of air even though there was a hole worn in the inside sidewall.
« Reply #4 on: July 31, 2009, 11:22:51 AM »
title should be changed to i keep beating a dead horse and for some reason i'm suprised at the results
« Reply #5 on: July 31, 2009, 12:10:16 PM »
I finally replaced the tires on the CRX 2 days before it took a shit.
Previous ones had belt showing through.  The two front ones had what looked like tears in the sidewall.  One had a hole in the sidewall but was still looking somewhat inflated?  Driving on a wet road above 40mph made adrenaline pump.  Hitting a puddle would make you cross fingers.
New ones are much fucking nicer.  Takes 10x less effort to turn the wheels.  Car died before it rained so I haven't been able to test that out but was looking forward to it.
You have bad luck or should quit buying used tires.
98redcavz24
  • NE Crew
« Reply #6 on: July 31, 2009, 12:12:47 PM »
o      k
« Reply #7 on: July 31, 2009, 12:33:51 PM »
You asked me before if I had seen this. Its worst-case what happens when you rotate tires side to side. The belts push against each other instead of constantly pulling tension.
speedjunky01
« Reply #8 on: July 31, 2009, 12:38:12 PM »
when was the car aligned last??
Not my cars.
The EP3
there is the problem right there
« Reply #9 on: July 31, 2009, 01:58:30 PM »
Not my cars.
The EP3
You, sir, are a man of taste and intellect.
« Reply #10 on: July 31, 2009, 02:23:59 PM »
Wat?!
Nobody likes the underpowered mini-mini-van with dildo shifter?
98redcavz24
  • NE Crew
« Reply #11 on: July 31, 2009, 04:56:18 PM »
fuck an egg-mobile. u used to smoke the shit outta them in my 200k daily stock z24. k2000000000000000 yyeeaaaa boyzz
speedjunky01
« Reply #12 on: July 31, 2009, 11:00:59 PM »
the k20a3 is a glorofied d15z1 that gets worse milage
either way GL on solving the issue JD
Toysrme
« Reply #13 on: August 01, 2009, 02:22:04 AM »
mine last month doing 80 on the interstate :\ it went boom
« Reply #14 on: August 01, 2009, 03:31:19 AM »
i bought a wrecked paseo a few years back, the car had been sitting for about 3 years and all the tires were totally flat/smashed down(i bought it for the rims/motor).
i pumped them up and 2 held air so i threw them on my corolla, these fuckers had cracks that were 1/4'' deep on the sidewalls totally dry rotted but the tread was still deep.
i ran those tires for 2 years strait every day 30 or so miles every day.
the one day i forget my cell phone at home one of the tires lets go, oh yeah it was -20 that day and windy as fuck.
i had to drive to the houses near where i was and ask to use a jack and wrench, somehow i took them out and never put them back in.
total fail, my buddies used to make comments on those tires all the time about they would blow any sec.
5thgenlx
« Reply #15 on: August 01, 2009, 02:01:54 PM »
holy fuck teh only time i've seen that is when i've ridden 20k past bald. you definitely have some bad luck on you
« Reply #16 on: August 02, 2009, 03:28:12 PM »
My friend's EP3 had the whole damned wheel fall off. Nogs at the brake shop decided to torque his lug nuts with their 5000ft/lb gun, from which 3 of the studs snapped off.
Funny thing about my current car, I've had the same tires for about 6 years now. Yokohama Parada Spec2's, most awsomest tires you can have on the street IMO, at least for daily driving. Their more common ES100's suck ass though.
« Reply #17 on: August 02, 2009, 08:31:41 PM »
Jd, you need to cut off your tread with a kitchen knife, then fill in the dry rot cracks with shoe polish, and you'll have slicks to pass track inspection.
« Reply #18 on: August 02, 2009, 08:39:38 PM »
Doing 60mph
The tire was still inflated and had drove it another 100 miles @ 40mph. That fucking sucked.
« Reply #19 on: August 02, 2009, 11:29:10 PM »
d112crzy - bet that was a loud fucking ride
d-rail
« Reply #20 on: August 03, 2009, 03:33:43 AM »
Trailer tire exploded on the interstate on the way to taking widebody's car to the dyno. Scared the hell outta me.
« Last Edit: August 03, 2009, 03:36:33 AM by d-rail »
« Reply #21 on: August 03, 2009, 05:06:07 AM »
Jorsher, you make me want to cry.
« Reply #22 on: August 03, 2009, 09:20:30 AM »
That's what she said  ???
What did I do?
« Reply #23 on: August 03, 2009, 10:04:34 AM »
I think you haven't experienced the Y-49 curse because your Y-49 reached through time to make you pay your penance, before you ever bought the vehicle.  No wonder it's been a good vehicle to you.  At this point it loves you.
« Reply #24 on: August 03, 2009, 10:39:22 AM »
Haha, my destiny :noel:
Breaking right after I put on some new tires is not a way to show love  :'(
« Reply #25 on: August 03, 2009, 02:23:59 PM »
I must be the only one that hasnt had a blowout  :?:
« Reply #26 on: August 03, 2009, 02:26:01 PM »
Don't you have an S10 thread to offer expert advice on?
« Reply #27 on: August 03, 2009, 02:53:11 PM »
S10's are just like JD they SUCK  :-*
« Reply #28 on: August 03, 2009, 04:46:07 PM »
