Author Topic: General ignition timing question  (Read 11491 times)
« on: August 03, 2009, 07:19:08 PM »
How much adjustment does the distributor provide for ignition timing? I know some have smaller/larger slots than others that will affect this, but what is the approximate range in degrees from all the way retarded to all the way advanced at the distributor?
Re: General ignition timing question
« Reply #1 on: August 05, 2009, 04:10:07 AM »
+/- 9 degrees, sometimes more like +/- 8 on some distributor housings.
« Reply #2 on: August 05, 2009, 08:09:17 AM »
Thanks JD
« Reply #3 on: August 05, 2009, 09:59:34 AM »
NP
I don't know everything, but I know the limits.
« Reply #4 on: August 05, 2009, 01:21:41 PM »
-8 is what we usually were able to get when we did alot of nitrous cars. A guy down in sothern California one of the few guys to run 10's on a fmu daryl bacon use to slit open all the dist bolt holes. I have no idea what his base timing was but the way the car ran Im thinking almost nothing.
« Reply #5 on: August 05, 2009, 03:09:38 PM »
So total range is around 16-18 degrees of adjustment, sweet.
« Reply #6 on: August 05, 2009, 05:53:25 PM »
I thought total range was like 8-9
I kow with my car running if I go all the way from one way to the other on the dizzy it only changes my timing from about 12-19
« Reply #7 on: August 05, 2009, 06:49:24 PM »
You just completed contradicted yourself.
edit: you must mean it changes from 12 deg. advanced to 19 deg. advanced, I thought you mean it changed in a total range of 12 to 18 degrees.
« Reply #8 on: August 05, 2009, 06:52:03 PM »
My bad I forgot to add ish at the end of 11-19"ish"
And I now see that I typed 12 instead of 11.....lol
« Reply #9 on: August 06, 2009, 12:20:44 AM »
What
« Reply #10 on: August 06, 2009, 12:32:20 AM »
yes
« Reply #11 on: August 06, 2009, 12:33:38 AM »
I still don't understand what you were trying to say.
« Reply #12 on: August 06, 2009, 04:04:27 AM »
you should swallow like a faggot tranny bitch and start tuning VW's.
The rest is easy to understand.
« Reply #13 on: August 06, 2009, 09:47:05 AM »
I hereby pronounce the usefulness of this thread to be at an end.
« Reply #14 on: August 06, 2009, 11:51:11 AM »
kO
