Author Topic: @ what psi does a dsm bov start leaking?  (Read 23208 times)
« on: August 06, 2009, 12:16:27 PM »
crushed and uncrushed please
Re: @ what psi does a dsm bov start leaking?
« Reply #1 on: August 06, 2009, 12:24:58 PM »
+1 I'm wondering the same thing since I use thes BOV's
« Reply #2 on: August 06, 2009, 12:39:11 PM »
Iirc the 1G dsm bov starts leaking around 14psi, and modded can hold upwards of 25psi
« Reply #3 on: August 06, 2009, 01:05:01 PM »
Modded = crushed right?
« Reply #4 on: August 06, 2009, 01:17:27 PM »
Yes although there is a way to mod them that does not involve crushing them.
« Reply #5 on: August 06, 2009, 02:04:56 PM »
Crushed, jb welded, and redrilled
« Reply #6 on: August 06, 2009, 07:24:30 PM »
Yaa!
89hatchsir
« Reply #7 on: August 08, 2009, 07:12:19 PM »
http://dsm.dejonpowerhouse.com/
Lookup - 1g DSM BOV (Air Bypass Valve) Leak Stop Kit    under bov-misc-tools
Find out where lexi Belle lives I wanna rape her. and by rape I mean sweet gentle love....of the ass....and mouth
« Reply #8 on: August 08, 2009, 08:22:33 PM »
They leak at idle.  :P
No seriously though it will be cracked open under vacuum.
Best way is the dodge garage mod, crushing is primitive and doesnt work well.
Few folks have removed the cap and installed shims on the spring, seems to work well.
kgx
  • MR2fag
« Reply #9 on: August 08, 2009, 11:13:10 PM »
most people don't know this, but it's possible to modify the 2g valves so that they cannot leak at any boost level.
« Reply #10 on: August 09, 2009, 12:13:59 AM »
for serious?!?!  WOW thats fucking awesome.
98redcavz24
  • NE Crew
« Reply #11 on: August 09, 2009, 12:48:40 AM »
13
kgx
  • MR2fag
« Reply #12 on: August 09, 2009, 01:35:19 PM »
it's practically free too.
most folks never figured out how the valve actually works. the lower port of the diaphragm is supplied boost pressure via the hollow valve shaft. the trick is to plug the bottom of the valve shaft, drill a separate feed hole on the side of the shaft near the bottom by the valve seat and turn the valve around so the outlet is now the inlet.
voila, it's now a pull-type valve. boost now holds the valve shut. more boost holds it more shut. the valve only opens when there is pressure differential between the top and bottom ports of the diaphragm.
« Reply #13 on: August 09, 2009, 08:49:14 PM »
QFT
Dodge garage mod rulz.
« Reply #14 on: August 10, 2009, 01:24:47 PM »
Or you could just buy a stock VW valve for $25 on amazon and have the same thing.
« Reply #15 on: August 13, 2009, 01:27:58 AM »
Robb, tell me more. year of vw, pics, ect  :)
« Reply #16 on: August 13, 2009, 11:45:27 AM »
Its that same stupid plastic bov that vw uses on all the 1.8t's, its made by bosch and dirt cheap.  You put 60k miles on one and they might leak, but who the fuck cares when they are so cheap?  They work in push and pull forms.  For a high power application you might want to actually get something "real" but ive ran 2 of these bosch valves in pull form on my old supra and they work great.  Ill find a link...
Also, there is a larger version made of metal that the porsche guys use successfully up to 850hp, I think those are like $120.
« Reply #17 on: August 13, 2009, 12:04:05 PM »
get the one with part # ending in 710 N. that's the upgraded version, the others tend to tear diaphragms.
