Author Topic: Ryan's project: Slutbox  (Read 26231 times)
« on: August 07, 2009, 09:23:36 PM »
Don't think ive ever had a build thread on HMT, so here is the latest project. Hopefully it will be finished in a month or so.
Picked up an '88 DX hatch from a member on d-series 2 weekends ago, got a pretty good deal on it. Only real drag is the 8hrs round trip I had to make to get it, no biggie though. He threw in a obd0-obd1 mpfi conversion harness, so I couldnt pass up the deal. I paid $400 cash and a small trade for it.
Pics of the car:
Coming home
Where she sits until the motor is finished and the title is in my name
Interior
As far as what motor is going into it...I'll be re-building my rod/piston a6 and transplanting it into the hatch along with the turbo kit from the CRX.
Motor is an a6 that I picked up locally. Guy said that it had a slight knock, and it turns out the #2 bearing was toast, but hadn't spun. rod was fine, and crank looked like it could be re-used no problem...but I'll be using the crank out of the last build just to be sure.
When I tore it down, still had crosshatch marks from the factory....with 250k on the clock
Front
Back
My 5 minute notching job
Motor fresh from the machine shop
75.5mm bore, with a .0035 P2W clearance for the SRPs
Sexiness
Today I got the bottom end assembled. Rings filed and all bearings plastigauged. New main bearings, but I'll be re-using the rod bearings because they still look perfect and I know the clearances are good.
All in all, I got the bottom end all assembled, rear main seal bolted on, water pump and oil pump bolted up, and oil pickup installed. Need to pull the engine out of the CRX so I can pull the head and oil pan and complete the assembly.
Plastigauging the mains
Rods/pistons installed
Rods torqued
Girdle torqued down
bang bang!! The 3rd time around for these pistons :P
Re: Ryan's project: Slutbox
« Reply #1 on: August 07, 2009, 09:32:40 PM »
Good stuff Ryan. Keep it updated!
« Reply #2 on: August 07, 2009, 09:53:34 PM »
classic hmt stuff
I for one will never have a piston set outlast my turbo/car
« Reply #3 on: August 08, 2009, 12:53:30 AM »
Nice find!  No rust is good.....
AJxr
  • i aint ur buddy pal
« Reply #4 on: August 10, 2009, 08:36:28 PM »
i love slutboxes.
90 hatch
« Reply #5 on: August 10, 2009, 09:10:33 PM »
Looking good. Your truck and house are a bit nice for this place though  :noel:
« Reply #6 on: August 10, 2009, 09:20:58 PM »
+1
Dr. D-Series
« Reply #7 on: August 10, 2009, 09:33:18 PM »
Sell me that ebay header I spy for dirt !
D16Y8-Z6.
« Reply #8 on: August 10, 2009, 10:10:41 PM »
nice... :yes:
n2o_2k
« Reply #9 on: August 10, 2009, 10:51:35 PM »
+1
+2
hatchbox90
    • Dream Builders Homes
« Reply #10 on: August 11, 2009, 09:45:48 PM »
little kid haha
« Reply #11 on: August 11, 2009, 11:22:37 PM »
looks good man, where in wa. do you live?
« Reply #12 on: August 12, 2009, 12:33:51 AM »
I believe he lives on the 509.
« Reply #13 on: August 12, 2009, 09:23:16 PM »
little kid haha
shit son, quit slackin and lets tune your shit
« Reply #14 on: August 12, 2009, 10:09:43 PM »
fresh machined blocks give me wood
hatchbox90
« Reply #15 on: August 12, 2009, 11:08:05 PM »
little kid haha
waiting for cooler weather so my shit doesnt overheat.  Seems to be less blowby than before though.  Catchcan only has a little bit of oil compared to lots of bit like last time haha
block looks sexy, i have your speaker wire for your shop too.
Soo whenever you want to tune let me know and ill drive my shitbox to work and just stop by your house afterwards. 20psi is going to make me shit my pants
« Reply #16 on: August 12, 2009, 11:37:16 PM »
little kid haha
any night during the week pretty much. i am home by 3 so whenever you are off we can get shit done. remind me to bring my vid camera for ripper vids
hatchbox90
« Reply #17 on: August 13, 2009, 12:33:24 AM »
little kid haha
Next week sometime then, ill let you know
back to thread
hatchbox90
« Reply #18 on: August 21, 2009, 08:58:33 PM »
updates? bitchtits
« Reply #19 on: August 21, 2009, 10:55:37 PM »
updates? bitchtits
fuckballs
josh is supposed to come get his Jeep out of the shop, then the real shit is going down.
when you gonna hook it up with that exhaust?  :mexi:
« Reply #20 on: August 30, 2009, 11:21:59 AM »
Updates?
« Reply #21 on: August 30, 2009, 11:27:28 AM »
Updates?
this just in Chris Harris is a bitch.
« Reply #22 on: August 30, 2009, 11:30:05 AM »
AJxr
« Reply #23 on: August 30, 2009, 12:07:36 PM »
so whats the story for a turbo setup here?
90 hatch
« Reply #24 on: August 30, 2009, 01:05:43 PM »
lol, just got my brother's Cherokee out of my shop Thurs, so Ill be working on swappage this week and next weekend. This weekend I cleaned the shit out of the shop getting it ready.
Went to hand in all my paperwork for the title to the hatch Fri, so its finally registered in my name and title is on the way  :noel:
plans for the hatch?
(all of this shit i have, just needs to be swapped out of the CRX and into the hatch)
a6 block
TT i-beams
SRP 75.5mm pistons
stock port a6 head
Delta 272
Blox IM
62mm TB
cable SI trans with OBX LSD and .702 5th gear
Competition Clutch stg4 6 puck sprung
JKMotorsports traction bar
my same old ghetto mini-ram if it will fit the new turbo
HX35 with 12cm exhaust
3" DP
3" exhaust
blah blah blah, same old HMT kit everyone has beyond that
obd1 conversion
chipped p06
Crome or ECtune, havent decided....probably Crome to start and then down the road switch
750cc injectors
3bar map in stock housing
CRX went 12.87 @ 109 with the same engine/trans setup but smaller turbo. boost wasnt stable(bounced from 16-21 the whole time), and i broke the 2-3 shift fork on my fastest run...so there was definitely more in it. with a bigger turbo and more boost, it should have even more yet
