Author Topic: holset lowest psi  (Read 17195 times)
shogun
holset lowest psi
« on: August 09, 2009, 04:00:32 PM »
hey, does any body know what is the lowest psi you can get in a holset actuator in a he351cw turbo?
Re: holset lowest psi
« Reply #1 on: August 09, 2009, 06:24:36 PM »
what the fuck are you asking this shit for.
boost is supposed to go UP not down.   ???
QikEnuF
« Reply #2 on: August 09, 2009, 06:37:17 PM »
Obvious answer is 0.  However, just set it to nog and rip it
AJxr
  • i aint ur buddy pal
« Reply #3 on: August 09, 2009, 07:46:51 PM »
400psi is lowest
90 hatch
« Reply #4 on: August 09, 2009, 07:49:31 PM »
OVER NINE THOUSAND
Wicked
« Reply #5 on: August 09, 2009, 08:04:36 PM »
I am sorry but go over to homemadeturbo.com and ask stupid ?,,,,
« Reply #6 on: August 09, 2009, 08:16:51 PM »
come on guys, just try and help him out. He is probably just trying to save from buying an external gate.
OP, when i had a hx35 i did some research and i thought i came up with 20+ on the stock wastegate actuator.
but if you creative you can go buy a universial wastegate actuator and make a custom bracket to hold it. this way you can set it up to run w/e boost you want.
Avistar23
« Reply #7 on: August 09, 2009, 10:24:12 PM »
I have the same turbo and was told it came with a 21psi gate, i went external so i dont know first hand.
F250 4x4 7.3 Diesel
International 4900 DT 466E
« Reply #8 on: August 09, 2009, 11:17:56 PM »
I have not seen an he351cw on industrial apps yet (not saying it isn't out there just I have not come across it in my travels)
The stock waste gate, if you are to get one from a dodge truck, will open at ~ 26 - 28psi.
« Last Edit: August 09, 2009, 11:28:45 PM by dvst8r »
« Reply #9 on: August 09, 2009, 11:20:22 PM »
Oh and it's little brother the HE341cw (they look the same from the outside [other then the HE351 has that big black electronic wastgate actuator], but the 341 has a 54mm compressor and 58mm turbine vs the 60/60 on the HE351cw) Opens at 22-24psi.
« Last Edit: August 09, 2009, 11:26:50 PM by dvst8r »
shogun
« Reply #10 on: August 10, 2009, 12:01:54 PM »
thing is we ordered a external wastegate, they fucked up the order and sent something else, since were in guatemala, shit takes forever to get here, specially since we had to send every thing back and they have to send the wastegate, so we wanted to get the car started and street tuned so when the wastegate comes we can dyno the car
« Reply #11 on: August 10, 2009, 02:03:55 PM »
external gate is your answer sir
« Reply #12 on: August 10, 2009, 02:16:15 PM »
Race gas street tune it is...  :P
shogun
« Reply #13 on: August 10, 2009, 08:53:14 PM »
i have a couple of hks actuators here from another project, ill use that one until the people we bought the wastegate send us the wastegate
AstroVannin
« Reply #14 on: August 13, 2009, 07:32:21 PM »
This sounds about right  :yes:
speedjunky01
« Reply #15 on: August 13, 2009, 08:41:26 PM »
DreaMeR
« Reply #16 on: August 14, 2009, 12:28:32 AM »
WHAT NINE THOUSAND??!!
« Reply #17 on: August 15, 2009, 12:50:08 PM »
So did those monkey guys ever get to destroy mojin boo? Shit got so boring I had to stop watching. 5 min episodes stretched to 30 mins.....
