Author Topic: If you were buying 10W 10ohm resistors...  (Read 13972 times)
« on: August 10, 2009, 12:20:46 AM »
Which one would you by from digi-key?  This is going to be a cheap resistor box for injectors.  I'm no electronix xpert and just wanted some input frome some one else
As cheap as can be.  Wonder if reliability is an issue
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=10W-10-ND
A bit more expensive but has some better tolerances.  Probably will order 4 of these
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=RSD-10RCT-ND
Re: If you were buying 10W 10ohm resistors...
« Reply #1 on: August 10, 2009, 04:45:34 PM »
radio shack ftw
« Reply #2 on: August 11, 2009, 06:19:11 PM »
If you're going to get them, get 6.8 ohm resistors.  That's what Honda/Toyota/DSM are.
That 10 ohm shit is just what's found on the shelf at Radio Shack.
« Reply #3 on: August 11, 2009, 11:27:10 PM »
Can i ask why the 10 ohm is used if it is supposed to be 6.8 ohm? besides accessability at radio shack.
« Reply #4 on: August 11, 2009, 11:50:45 PM »
i think thats about it
« Reply #5 on: August 11, 2009, 11:58:18 PM »
No, you can't ask.  Take it back!!
« Reply #6 on: August 13, 2009, 12:49:29 AM »
oh look jd fails to explain what the fuck he said. thanks
« Reply #7 on: August 14, 2009, 08:17:41 AM »
The les power you drop across some dorky resistor instead of the injector, the shittier they operate.  Any electro-mechanical device is the same way... do you want 8v or 12v going to your starter for best effect?  Etc.
« Reply #8 on: August 15, 2009, 02:19:00 AM »
real ballers tear the ni-chrome out of a toaster heating element  O0 :mexi:
« Reply #9 on: August 22, 2009, 10:34:00 PM »
Ohm's Law (for voltage): V = I * R
Voltage = Amperage * Resistance
Add more resistance, and you'll need more voltage to supply the same current. As JD said, less power to a solenoid (injector), and the slower & more erraticly it opens. The honda resistor box I have next to me is reading 6.5ohms fyi. The 2nd style only offers 5 & 10ohm, the other has 6.8ohm. That 5% will maybe affect opening speed, but that accounts for a small amount at idle, and far far less with high rpm & boost.
