Author Topic: Y8 head on a z6 block a lil help needed  (Read 11285 times)
TheMadScientist
  • I'm like Batman and Shit
« on: August 17, 2009, 02:19:39 PM »
Alright so I've been reading up on this and have a question. I know questions about this setup have been asked a million times so bear with me please.
Can I put the y8 head on the z6 block with the z6 cam and cam gear on it?
Also then what timing belt do I use?
All the shit I've been reading on the net has me all sorts of confused and can't find this specific question anywhere.
Re: Y8 head on a z6 block a lil help needed
« Reply #1 on: August 17, 2009, 04:35:50 PM »
so your just changing the head casting.......why would the timing change?
TheMadScientist
« Reply #2 on: August 17, 2009, 08:01:30 PM »
That's my thought process as well. There's more too it than that though.
« Reply #3 on: August 18, 2009, 12:01:23 AM »
Really? where????
Only ting will be bump in compression from the smaller chambers and maybe the need to open the slots on the dizzy to get 16 BTDC ignition timing.
You'd need a "non" VTEC style dizzy though, which I consider a big plus.
TheMadScientist
« Reply #4 on: August 18, 2009, 12:06:02 AM »
The dizzy is one thing that's more to it. And I hadn't been able to find the answer about using the z6 cam and cam gear. Everyone was swapping cams and gears with each other which changes timing like 4.5* but I couldn't find the answer to if I use a z6 cam and gear. It should work fine though I guess.
« Reply #5 on: August 18, 2009, 12:09:16 AM »
Your staying with a same height block, same height head, therefore if the cam gear matches the cam. nothing changes.
This is simple stuff.
TheMadScientist
« Reply #6 on: August 18, 2009, 02:00:44 AM »
And the head is the same height correct. These where things I was assuming but had been unable to verify. I appreciate the help.
« Reply #7 on: August 18, 2009, 01:46:02 PM »
searching owns you
TheMadScientist
« Reply #8 on: August 19, 2009, 02:43:49 PM »
Searching Destroys me. If you found it with the search please show me because I'm being ass raped with a huge dong by the search feature.
« Reply #9 on: August 19, 2009, 03:03:32 PM »
dude.  my fuckin build thread is stickied on in the FI topic.  its the same shit...a6=z6 block
« Reply #10 on: August 19, 2009, 03:07:08 PM »
use a z6 belt.  keep the cam gear with the correct cam...
z6 cam use z6 gear
y8 cam use y8 gear
TheMadScientist
« Reply #11 on: August 19, 2009, 05:02:24 PM »
Thank you. I was searching for Z6 the whole time DOH! That's why I couldn't find it. I had assumed it would be that way but was looking for verification. Thanks again.
