Author Topic: what do u use for cleaning SS?  (Read 19626 times)
walter
« on: August 24, 2009, 02:56:30 PM »
what title says, i usually use wire whell brush...
Re: what do u use for cleaning SS?
« Reply #1 on: August 24, 2009, 04:04:33 PM »
to polish ss when i weld it i use 3m red surface conditioning pads. they can be found at any welding supply store thats worth a shit. And for things like cleaning welds in between passes, etc.... i use a simple wire wheel.
If my material is dirty, or has some left over lube from bending acetone works great for cleaning it.
« Reply #2 on: August 25, 2009, 02:59:10 AM »
i wipe everything down with acetone before welding.
even the filler rod. youd be amazed how dirty it actually is.
« Reply #3 on: August 25, 2009, 04:20:11 AM »
just make sure you keep your solvents away from the light that comes off your torch, phosgene is a bitch
« Reply #4 on: August 25, 2009, 09:32:48 AM »
Or use brake cleaner instead of acetone and die next week ;)
« Reply #5 on: August 25, 2009, 12:26:16 PM »
Wire brush or wire wheel is fine, as long as they are stainless steel and only get used on stainless steel. Start using them on mild steel as well and than try using them on stainless again and your stainless will rust. I use teh 3m pads a lot too.
« Reply #6 on: August 26, 2009, 12:18:20 AM »
yeah because everyone is buying clorinated brake cleaner.....  :?:
Toysrme
« Reply #7 on: August 31, 2009, 05:42:54 PM »
stainess wire brush & acetone on a scotchbrite pad.
mandrel-bends
« Reply #8 on: September 03, 2009, 10:33:55 PM »
I will go against the flow here and argue that cleaning is most of the time unnecessary unless it has visible contaminates (dirt, crap, etc). I get so many entry level welders in the doors that will take a perfectly clean, mill finished piece of tubing and then spend 5 minutes wiping it down with acetone, wire brushing the ends until they are blue in the face and then getting similiar or worse results then what they could have gotten without.
I personally teach my employees that wire brushing tends to add more contaminates then it removes unless you are very careful about not cross contaminating the brush with other materials. In a shop environment specifically, where it's very dirty and people are borrowing tools all the time, I don't even give them prep materials.
This is a typical result of our no prep procedure. I would push technique and fit up any day over time spent on cleaning & brushing.
Notice the color on even a stainless to mild flange.
« Last Edit: September 03, 2009, 10:41:09 PM by mandrel-bends »
http://www.mandrelbends.com
ifly87
« Reply #9 on: September 03, 2009, 10:48:16 PM »
A scotchbrite pad with some baby oil will make it shine.
Lol...Fags
« Reply #10 on: September 04, 2009, 07:12:07 PM »
i dont think cosmetics was the goal here smart guy
« Last Edit: September 04, 2009, 09:30:41 PM by SecksyPeePee »
walter
« Reply #11 on: September 11, 2009, 09:00:22 AM »
thx for replies, what o want to get is something like this:
« Reply #12 on: September 11, 2009, 09:14:45 AM »
That looks like food Grade Sanitary Stainless.. We have a place that sells it locally... Nice stuff but not cheap..  I bought one of those transitions  2-2.5"  $18.... It does weld up nice though.
If thats the stuff you are using, you don't even need to clean it.
mandrel-bends
« Reply #13 on: September 11, 2009, 12:11:37 PM »
Just use a scotchbrite metal finishing wheel on a bench grinder to get that finish. Then run your tig at 1 amp per thousandth with no filler to get that look with a gas lense.
« Last Edit: September 11, 2009, 12:13:47 PM by mandrel-bends »
« Reply #14 on: September 11, 2009, 12:34:17 PM »
If you want it to look like that buy sanitary stainless, you can get mill grade tube to look similar with a bit of work but not quite.
« Reply #15 on: September 11, 2009, 12:35:00 PM »
That is a real kicker people don't even think about, contamination is a mother fucker.
We build machines out of 316 SS sheet metal and we had a couple former employees take all of the stainless wheels to mild welds first.  Now we have a few $60k machines that have been in the field maybe a year with every weld rusting.  Now I keep every SS wire wheel in my desk and soak it in water as soon as I get it back so I can bust the fuck that uses it on mild when the water turns orange.
mandrel-bends
« Reply #16 on: September 11, 2009, 12:58:20 PM »
 :o
Aint that a bitch! Hope your not personally liable!
« Reply #17 on: September 11, 2009, 02:25:36 PM »
no ones complained yet.  I thought they all got fixed but I just noticed 2 last month.  I made a note and we'll make a surprise visit to clean it up before it gets too bad.
walter
« Reply #18 on: September 11, 2009, 08:09:43 PM »
thx, ill use mandrel-bends 16gauge ss.
where do i can get those?
walter
« Reply #19 on: October 22, 2009, 04:58:18 PM »
weirtech
    • Weir Technologies Inc.
« Reply #20 on: October 22, 2009, 10:55:36 PM »
walter, that pic is markku's work from http://agtronicmotorsport.com/  he only uses sanitary grade stainless.  i'm not sure of his cleaning method though.
personally, if the material has grease on it or something, i just use an all purpose cleaner and a clean rag.  not acetone.  usually i'll wire wheel the joints before welding, but not always.  you have to be sure to use a 100% stainless wire wheel though and not those cheap carbon wheels that are coated.  you might as well use a plain carbon wire wheel then.  for manifolds, i wirewheel the entire weld el before welding, just so it all looks uniform at the end.
Hotrodlincoln
« Reply #21 on: October 22, 2009, 11:38:12 PM »
3m roloc dude.
kill yourself piss face
« Reply #22 on: October 23, 2009, 12:55:03 PM »
Its too bad you are in spain, all the european Sanitary SS is all Mill grade finish, you can get ornamental stainless tube though with a polished or brushed finish.
darksol2005
« Reply #23 on: October 23, 2009, 01:24:01 PM »
roloc 3m pads, and sometimes acetone and I'm golden.  I always use a NEW pad, or one that I know has only been used on stainless though
