Author Topic: when building a twin scroll......??  (Read 26643 times)
toyolla86
« on: August 27, 2009, 02:40:58 PM »
so ive been reading some stuff saying that when you build a twin scroll you need to pair the runners.
how important is this.
say i wanted to build a log manifold, would that be totally stupid on a twin scroll turbo.
you typically want 1-3 and 2-4 together right.
twin50 son. get some
and stop acting like a muslim
toyolla86
Re: when building a twin scroll......??
« Reply #1 on: August 27, 2009, 02:48:26 PM »
maybe ill eliminate the twin scroll. and run it like a single scroll.
« Reply #2 on: August 27, 2009, 05:40:42 PM »
yeah the point of running divided is to increase the pressure on the turbine wheel by separating the exhaust pulses. running a log is not separating pulses.
BRIAN MP5T
« Reply #3 on: August 27, 2009, 05:54:14 PM »
The Twin is normally used with a tube style equal length manifold.
If you don't use a Tube mani, it's defeating the point of the housing.
« Reply #4 on: August 27, 2009, 06:02:07 PM »
But you dont need to have a twin scroll to run a twin scroll. Look at joes (d16y8-z6) holset on his log that hes running mid 10's in on his civic.
« Reply #5 on: August 27, 2009, 06:03:39 PM »
yeah but what would the gains be if he did it correctly?
« Reply #6 on: August 27, 2009, 06:08:34 PM »
I would imagin faster spool time. But this dude is talking about running his twin on a log, so just slap it on.
klyph
  • Proletariat for Life!
« Reply #7 on: August 27, 2009, 06:15:40 PM »
 I thought SPLOG stood for split pulse log...
« Reply #8 on: August 27, 2009, 06:18:00 PM »
I thought it stood for split log.
« Reply #9 on: August 27, 2009, 06:53:07 PM »
log
Splog
« Reply #10 on: August 27, 2009, 07:09:17 PM »
I'm running a twin scroll on what's basically a cast log manifold. It works fine. Yeah, it would spool better if I had a 4:2 header for it, but this works good enough. If I had to redo it I would make a weld-ell 4:2 manifold for it.
toyolla86
« Reply #11 on: August 27, 2009, 07:49:34 PM »
but technically that SPLOG isnt even correct if it is supposed to be
1 and 3
2 and 4
right?
eh i dont think it really matters that much. its all pumping exhaust. hahah.
it would really only make a huge difference if when it hits a certain rpm a second scroll opened up like
that old thread was talking about on ohmt. where it had a flapper that would open a whole new port to the twin scroll
« Reply #12 on: August 27, 2009, 08:24:21 PM »
1342 is honda firing order isn't it?
Yep, at least the ones i work on.
« Reply #13 on: August 28, 2009, 12:49:42 AM »
no.
on a honda you pair 1+4 and 2+3 on divided housing setups.
« Reply #14 on: August 28, 2009, 01:00:27 AM »
no.
^^^this
toyolla86
« Reply #15 on: August 28, 2009, 02:08:14 AM »
i was thinking this may be the actual way.
and i think most cars would be 1-4 and 2-3
so i am corrected.
but i will have to research for a ka24de
« Reply #16 on: August 28, 2009, 02:18:53 AM »
ka is the same as a honda
« Last Edit: August 28, 2009, 02:21:00 AM by Corey »
toyolla86
« Reply #17 on: August 28, 2009, 12:36:57 PM »
very well. 1and4 it is.
that obviously takes much more tubing. which we dont have. hahah. and they would definitely be unequal runners.
« Reply #18 on: August 28, 2009, 01:15:57 PM »
equal length is not all that important.
just order up some bends there dirt cheap $5/e
« Reply #19 on: August 28, 2009, 01:27:43 PM »
Like said b4, unequal  length is not a huge deal. I would take setting up the runners for a split over equal length any day.
kgx
  • MR2fag
« Reply #20 on: August 28, 2009, 04:09:53 PM »
tell me you're using an EVO turbo and not a CT26! CT26=doorstop.
toyolla86
« Reply #21 on: August 28, 2009, 04:58:23 PM »
tdo5hr
Toysrme
« Reply #22 on: August 30, 2009, 05:06:54 PM »
truth
toyolla86
« Reply #23 on: August 30, 2009, 08:57:57 PM »
maybe that'll have to be done.
