Author Topic: Tig Welding Aluminized  (Read 35926 times)
« on: August 30, 2009, 01:08:19 PM »
I was working on a downpipe for RatCityRex yesterday and no matter how much cleaning I did I could not keep the shit from getting contaminated.  Is there anyway around this?  I would clean it with MEK, hit it with the red conditioning pads on my die grinder, reclean with MEK still got nasty.  What do you guys do to get the shit clean?
Re: Tig Welding Aluminized
« Reply #1 on: August 30, 2009, 01:43:02 PM »
I grind the pipes down to get the aluminized shit off, then weld it. Works great. Doesn't look like you got it all off to me.
« Reply #2 on: August 31, 2009, 06:33:28 AM »
I usually use green cookie wheels to grind it all the way through. You will also need to go further back than you think.
weirtech
    • Weir Technologies Inc.
« Reply #3 on: August 31, 2009, 07:55:41 AM »
i don't weld it!  i hate tig'n that shit.  i just mig it.
« Reply #4 on: August 31, 2009, 08:02:03 AM »
i just take a red pad and go to town on it. you will see 2 shade of metal. one is just the coating getting polished up, you need to go deeper, then you will see the steel under the coating.
and like cs said go more then you think.
« Reply #5 on: August 31, 2009, 09:50:43 AM »
+1
« Reply #6 on: August 31, 2009, 11:46:17 AM »
dip it on meriatic acid, shit boils like crazy and lets off a bunch of fumes but its perfectly clean
Toysrme
« Reply #7 on: August 31, 2009, 05:41:20 PM »
you likely contaminated the fuck out of the tungsten too. aluminuzed and galvanized can make you so ill youll consider death afew hours away. becareful welding it.
meriatic acid FTMFW. also great for cleaning concrete  :noel:
« Reply #8 on: August 31, 2009, 09:28:38 PM »
muratic acid
works great on drive ways
« Reply #9 on: September 01, 2009, 01:38:55 AM »
youre not gonna get color out of aluminized steel. its going to look grey and shitty. only time ill tig that shit is if its something low stress that i can just rip a quick fuse pass on and i usually wear a mask and breath as little as possible.
glavanized can very well kill you, aluminized is not nearly as harmful. i wouldnt weld galvanized even with a mask outdoors. aluminized will give you a sore throat/cold symptoms/raging migraines. thats what i get anyways
« Reply #10 on: September 01, 2009, 02:21:47 AM »
that and putting 2 welds on a pipe won't kill you. unless your huffing the shit.
I just hold my breath and make a pass, then use the air hose to cool /blow away fumes. it works.
« Reply #11 on: September 01, 2009, 10:18:27 AM »
Never had  health problem welding aluminized steel. Is it only with tig welding? I have like 2398723846 welds on my exaust...
I weld outside tho...
toyolla86
« Reply #12 on: September 01, 2009, 11:05:39 AM »
i think lye and murriatic acid are the same thing
twin50 son. get some
and stop acting like a muslim
« Reply #13 on: September 01, 2009, 11:43:17 AM »
no lye is potassium hydroxide, KOH a base-dont get this in your eyes
muriatic acid is and acid, im pretty sure Hydrocloric HCl-you get this in your eyes, wash it out quick and you will prob be ok
dont worry about acid, worry about bases.
« Reply #14 on: September 01, 2009, 12:08:08 PM »
Still turned out tits!!!
« Reply #15 on: September 01, 2009, 07:30:59 PM »
I'm gonna try go to town with a real grinder tonight on it and see how it comes out.
toyolla86
« Reply #16 on: September 01, 2009, 07:50:38 PM »
nice to know. i was mis-informed.
« Reply #17 on: September 01, 2009, 07:51:19 PM »
quote author: weirtech
just making sure everybody saw this and who wrote it...
« Last Edit: September 01, 2009, 07:55:09 PM by Conceptz-X »
toyolla86
« Reply #18 on: September 01, 2009, 10:58:05 PM »
hahaha
« Reply #19 on: September 02, 2009, 01:01:32 AM »
i dont see the point?
« Reply #20 on: September 02, 2009, 03:38:27 AM »
well i just welded up about 10 pie cuts into a 180*bend tonight. i hate grinding that coating off. smelled the shop up too.
AfroIntegra
« Reply #21 on: September 02, 2009, 06:52:44 AM »
Aluminized FTL. I had to weld up an adapter to this cherry bomb for this kid in class today. It was definitely pretty unhetero
Fuck your life.
« Reply #22 on: September 03, 2009, 10:11:55 PM »
It's rhmt's imitation of HT's nutswinging. Everyone know's weir is one of the local dieties. :noel:
I don't mind mig'ing aluminized for exhausts. It lasts a lot longer than mild steel. Welds are all that rust, and easy enough to clean occationally. 409 or 304 will be better rust-free shit, if you can payu for it.
mandrel-bends
« Reply #23 on: September 03, 2009, 10:28:20 PM »
Aluminized is not toxic to weld.
You don't need to prep the surface beyond basic cleaning.
The coating is designed to be welded through directly.
Don't wire brush it off around the welds or you would have been better off getting mild.
You can get some color in aluminized, but it's more technique then anything else.
http://www.mandrelbends.com
« Reply #24 on: September 03, 2009, 11:40:21 PM »
if by toxic you mean fatal then idk but i can gaurantee the fumes from welding can make you sick. ive experienced it personally
Toysrme
« Reply #25 on: September 03, 2009, 11:47:56 PM »
wrong
wrong
wrong
wrong, not an answerable question on the based information
you're a damned idiot
« Reply #26 on: September 03, 2009, 11:54:21 PM »
wrong
wrong
wrong
STFU Mr. Know it all that sucks balls at welding
« Reply #27 on: September 04, 2009, 03:14:22 AM »
wrong
wrong
wrong
Toys you know what you are a fucking idiot.... i have personally got color out of welds on mild steel and aluminized. it is all in the technique like stated by crmb.
And only thing i have noticed is that when tig welding aluminized it burns the edges and becomes flaky where you welded, a wire brush and that is gone. and also the occasional dirt in the welds.
mandrel-bends
« Reply #28 on: September 04, 2009, 01:40:03 PM »
Corey,
I was pointing out that the specific material in question isn't any more toxic the standard mild steel (atleast according to the material spec sheets). I would agree you should probably not be directly breathing in welding fumes regardless of the material being processed.
Adam
mandrel-bends
« Reply #29 on: September 04, 2009, 01:43:12 PM »
Who are you, to correct me? Sit down.
wrong
wrong
wrong
