Author Topic: anyone have a 2 post lift in there garage  (Read 8334 times)
7808
« on: September 01, 2009, 12:59:12 AM »
i was thinking about blowing some of my $8k new home buyer rebate check thing on a lift so i can make exhaust on the car and pull my noisy tranny out shti like that, anyone bought one of these cheap 2 post lifts for there home?
this site has some cheap ones
http://www.directlift.com/Two-Post-Lifts-C8.aspx
and of course http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=94844
am i going to die under one of these ? i bought a car from some guy who had a drive on lift in his garage at home and it was pretty fucknicool except i wouldnt buy one that didnt lift by the frame  drive on ones are stupid
Re: anyone have a 2 post lift in there garage
« Reply #1 on: September 01, 2009, 01:12:28 AM »
as long as it has locks, which all lifts do, theres nothing to worry about. i hope your garage cieling is at least 12 feet
« Reply #2 on: September 01, 2009, 01:33:10 AM »
if you were local i could get you a 10K lb chicom lift for 2300 installed.
« Reply #3 on: September 01, 2009, 02:03:00 AM »
Damn!
« Reply #4 on: September 01, 2009, 02:29:31 AM »
i know when me and my friend bought lifts i paid $2400 installed 10k lb hanmecson, he got pretty much the same thing i got for right around there. great lifts for the money.
My friends has put a full size pickup on his, and i can say i won't stand under it. but it doesn't sway or anything.
« Reply #5 on: September 01, 2009, 03:00:40 AM »
how far into the ground do the posts go or are they just bolted to the floor?
I'd be a little worried if they were just bolted.  A little less worried if they went a couple feet into the ground/cement.
« Reply #6 on: September 01, 2009, 03:31:08 AM »
the lift i have in my shop is lagged to 6" slab. 8 lags per post. lifts 3500 lb cars without even a hint of moving.
« Reply #7 on: September 01, 2009, 03:35:03 AM »
im not worried. my floor was poured about 45 years ago.
« Reply #8 on: September 01, 2009, 10:13:38 AM »
Hoists need to be bolted into reinforced concrete. I know a few guys that have just cut squares out of their shop floor, dug down an extra 2ft and had new stuff poured in. Then a hiliti and a few friends and it is an easy job to install.
If I had the overhead room in my garage, I would have had one years ago.
« Reply #9 on: September 01, 2009, 11:02:47 AM »
You can get good quality, good shape lifts for a grand.   Installation is a bitch because they are super heavy, you can usually get one of the pro installers to do an afterhours job for less but you NEED a few strong boys to help erect them as the installer probably doesn't have shit beyond a concrete drill and some stuff to make chalk lines with.
« Reply #10 on: September 02, 2009, 04:00:39 AM »
Yeah i would think reinforced concrete would be a good idea. but if your not loading it all fucked up there shouldn't be an issue. i mean the lifts place the load evenly for the most part.
slaminsam
« Reply #11 on: September 02, 2009, 07:32:01 AM »
Hell if nothing else poor a new slab outside the garage. My grandpa put him a cheap two post on a slab right outside the shop considering he didnt have high enough ceilings. Its been out there for the past six years and is still in great shape. You just have to keep everything greased and when its cold as hell out the lift is slow. If you do buy a cheapy new one make sure you get one that is sufficiently wide enough. It sucks having to squeeze out the door on a truck or suv.
« Reply #12 on: September 02, 2009, 09:27:49 AM »
I've always wanted one of these. One day... But I think if I'm gonna spend the money I'm gonna get the biggest/strongest/best that I can afford. I got a homemade drive up lift and it sucks that it's not that long.
Jordy53
« Reply #13 on: September 02, 2009, 02:43:31 PM »
Wish I had room too, but I think Base Housing would shit a brick.
You cannot help the poor by destroying the rich. You cannot strengthen the weak by weakening the strong. You cannot build character and courage by taking away men'#39#39s initiative and independence. You cannot help men permanently by doing for them what they could and should do for themselves.
« Reply #14 on: September 02, 2009, 04:48:15 PM »
There is surely a GM Dealer going tits up in your town. I  am working on getting 2 from our local Defunct GM store...
about $800 a crack.
