Author Topic: fuel question with hx35  (Read 29521 times)
turboblack2door
« on: September 08, 2009, 09:23:59 PM »
rigt now i have evo 8 injectors. will these be enough for 400hp. My setup is a jdm d15b, extended length fjt rods, vitara pistons (.020 over), walboro 255, 2 3/4in ic piping, will have a 3in dp, aeromotive fuel pressure regulator, JGS 40mm wg, CSAddict tubular mani, gm 3bar MAP, chipped and socketed p28
« Last Edit: September 08, 2009, 09:41:02 PM by turboblack2door »
93 Honda Civic Del Sol -F22A6, H22 trans, Bisi rods, Aris pistons, Hondata S300, 1200cc RC injectors, e85, Koni Yellows, Ground Controls, fuck my expensive hobby
Re: fuel question with hx35
« Reply #1 on: September 08, 2009, 09:26:52 PM »
post pics  :yes:
turboblack2door
« Reply #2 on: September 08, 2009, 09:52:04 PM »
Just some teasers
« Reply #3 on: September 08, 2009, 11:24:10 PM »
post pics  :yes:
not of the setup, dumbass
« Reply #4 on: September 08, 2009, 11:56:26 PM »
You have too much compression for 400 whp.  Install a LARGE crankcase breather, run better than 110 octane, and pray to your Jesus because that small bore motor will bleed oil around the pistons after every 300+ whp pull.  Word to the wise: FJT long rods are an abortion in anything but a DOHC ZC.
OP, you really need to get your ass to www.rceng.com and use their injector worksheet.  You have excellent taste in turbos and manifolds, but you are 38 posts deep, unfamiliar, and have posted zero porn.  While I like the enthusiasm you've displayed so far if you want to fit in around here you need to display some basic competence (figure out what your injectors are good for by yourself) and get with the naked bitches.
Thanks, and I have faith in your ability to do the right thing.   :noel:
turboblack2door
« Reply #5 on: September 09, 2009, 07:12:44 AM »
im not a newb i just didnt know how to transfer my old name and the only reason for the question for the evo injectors is because i used them in my turbo ef sedan. i will definently look into rc's i was just wondering if what i have would be sufficant for my goal
« Last Edit: September 09, 2009, 07:46:32 AM by turboblack2door »
« Reply #6 on: September 09, 2009, 11:07:17 AM »
Why would you want to look into RC's?  Did you not read what I said?
« Reply #7 on: September 09, 2009, 11:49:59 AM »
Stay away from RC's and post porn. Nigger.
« Reply #8 on: September 09, 2009, 01:11:55 PM »
http://www.rceng.com/technical.aspx
What you lack in sarcasm you more than make up for in common sense, I hereby award you your first B in your college career.
bouncinofftherevlimiter
« Reply #9 on: September 10, 2009, 01:08:41 AM »
itll be about the limit if they do make it... i have a set i had with my HX35 build at 12psi...
now im running 880s, i didnt want any injector issues, but im also aiming for over 100hp more than you.
just FUCKING do it, dammit...
No longer own a turbo car...
HX35 18lb 486hp/391tq
« Reply #10 on: September 12, 2009, 06:13:00 AM »
stock top end d16 your not going to make the power you think sir
speedjunky01
« Reply #11 on: September 12, 2009, 11:59:30 PM »
says the guy selling bigger TB and manifold work  O0
just busting you chops, ill be ordering from you monday.
JD why are they an abortion? i plan on running std length rods and vitaras in my mutt d15b, suposed to stick out .020 and have right around 8.3:1
« Reply #12 on: September 13, 2009, 11:24:45 AM »
When you are dealing with a 75mm piston surface, 9:1 CR is too high for 300+ whp.  The presure spikes that precede detonation are unavoidable, and it takes it's toll on the ring seal.
Dr. D-Series
« Reply #13 on: September 14, 2009, 11:17:04 AM »
JD's almost my hero.
D16Y8-Z6.
« Reply #14 on: September 14, 2009, 02:14:40 PM »
Yeah, if I actually produced a turbo car of my own you'd be proud.   :'(
Dr. D-Series
« Reply #15 on: September 14, 2009, 09:14:28 PM »
Get to it.
D16Y8-Z6.
« Reply #16 on: September 14, 2009, 09:59:07 PM »
It will never happen.
« Reply #17 on: September 14, 2009, 11:17:55 PM »
How are you getting 9:1 static compression with vitaras in a D15B?  Hell with the long rods and vitara pistons in a Z6, static CR is only like 8.6:1.
Am I missing something here Grand Exalted Wizard?
« Reply #18 on: September 14, 2009, 11:29:23 PM »
I'm getting 9:1 from every forged piston abortion motor brought to me for tuning that bleeds oil around the piston perimiter past 250-275 whp.  Where are you getting D15B?
« Reply #19 on: September 14, 2009, 11:32:45 PM »
Yields roughly 8:1 static CR.
