Author Topic: start up, not idle ..  (Read 12775 times)
walter
« on: September 19, 2009, 12:15:00 PM »
well today i tried to start up my SOHC ZC (A6) engine, injectors 460cc, everything is stock.
i just made a basemap using NG62 final map , sometimes engine idles roughly , i was checking for  leaks, only found one in sandwich for oil gauge.. but that's not the problem i think, i checked one spark plug and was black, i think it's soo rich.
i can't upload my map here, im using PR4 chipped ecu
im uploading a video of how start it.
walter
Re: start up, not idle ..
« Reply #1 on: September 19, 2009, 12:36:23 PM »
btw, not CEL.
walter
« Reply #2 on: September 19, 2009, 12:46:13 PM »
walter
« Reply #3 on: September 19, 2009, 01:11:17 PM »
yes, i did, cam mark is fine and crank mark is off just but like 1mm maybe.. anyway i think that shuold runs better even..
walter
« Reply #4 on: September 19, 2009, 01:13:33 PM »
btw, another weird thing is rpm sometimes doesnt works in the cluster.....engine has +125K miles.
walter
« Reply #5 on: September 19, 2009, 02:40:40 PM »
Ok, tried with stock map and stock injectores and start up and idles very good, ill try to upload my map ..
« Reply #6 on: September 19, 2009, 05:05:22 PM »
PM me your email address and i will send you a good basemap i have. should run ok. it was made for 440's, but i can lean it a touch
speedjunky01
« Reply #7 on: September 19, 2009, 07:54:08 PM »
have you checked using the oil pump mark? Ive had the crank pulley be off a tad
walter
« Reply #8 on: September 20, 2009, 06:15:36 AM »
yes, of course.
SecksyPeePee, PM sent!
« Reply #9 on: September 20, 2009, 04:20:08 PM »
post you bin here
walter
« Reply #10 on: September 20, 2009, 07:00:52 PM »
fuel map
timing
walter
« Reply #11 on: September 21, 2009, 02:34:41 PM »
nobody?   :-\
walter
« Reply #12 on: September 21, 2009, 06:39:34 PM »
i was doing somethings wrong, ill try another map i did tomorrow.  :noel:
hotrex
« Reply #13 on: September 21, 2009, 06:55:31 PM »
walter
« Reply #14 on: September 22, 2009, 06:28:14 PM »
u sucks  :noel:
