Author Topic: Anyone Know about Subaru 4EAT's?  (Read 14706 times)
« on: September 21, 2009, 01:01:22 AM »
So i cant get the Tq converter back into a 4EAT transmission. I think my problem is that the input shaft slid out a bit but dont know for sure and it dosent want to go back in either if its out. So dose anyone have any info on thses, or know how far the input shaft is suppose to stick out?
spoonfedcrx
Re: Anyone Know about Subaru 4EAT's?
« Reply #1 on: September 21, 2009, 08:01:03 AM »
How would the imput shaft slide out a bit?
Only auto trans' I've ever fucked with have been Honda's.  Sometimes oddys torque convertors wont slide on kinda have to push and turn and wiggle it.
This is prob no help to you/
« Reply #2 on: September 21, 2009, 02:26:33 PM »
The inner shaft has to go through the stator in the converter.  Just keep wiggling it, sometimes it helps to stand the trans on end and shake the converter around til the stator lines up. Thats all slushomatics though.  If yours isnt that problem then fuck you I dunno.
« Reply #3 on: September 21, 2009, 03:03:17 PM »
stator and pump tangs need to line up,
one....two.....three.
« Reply #4 on: September 21, 2009, 04:35:23 PM »
im pretty sure its the input-shaft sticking out too far not allowing the pump tangs to line up. I talked to a subaru tech today and said the input should just wiggle and slide back into place but that dosent happen either. So IDK if i damaged the splines on something thats not allowing it to go back it or what but its not going  >:(
« Reply #5 on: September 21, 2009, 09:11:21 PM »
OK finally got the input shaft to slide in, but god dam did it take a lot of bad words and wiggling. Now the Tq converter just slides in like normal to the correct depth :yes:
« Reply #6 on: September 21, 2009, 11:33:37 PM »
nissan used the 4eat in their pathfinder
I dont give a fuck about a nissan pathfinder u homo
« Reply #7 on: September 22, 2009, 03:04:47 AM »
Still a virgin I see.
« Reply #8 on: September 22, 2009, 08:55:48 PM »
you were/are a subaru tech and you can't figure out how to get a transmission to line up on the converter?
I talked to a subaru tech today....
Obviously hes an independent, captain simplex.
AbaZ
  • Out of retirement
    • R-HMT
« Reply #9 on: September 25, 2009, 12:49:24 PM »
Stevey, everytime I drop a TQ convereter on the ground they never like to go back in. As you mentioned above, alot of cussing, pushing and wiggling.
you rolling a Subaru...? lol
« Reply #10 on: September 28, 2009, 12:11:30 AM »
Yep 1990 Legacy Shit brown  :?:
