Author Topic: The elusive answer to ignition breakup needed.  (Read 39015 times)
« on: October 05, 2009, 12:11:50 AM »
This mufuka is shitty.
Breaks up periodically between 7 and 8 grand.
Tried tuning the timing more on crome with no luck. Put hondata on it and the same thing. I've had 3 distributors on it, new rotors, caps, everything.
NGK 7's gapped at 20, then 19. Put the iridiums in it at 19.....nothing changes.
Put on an msd blaster ss ext. coil (not the canister kind). Car ran stronger, still with breakup.
On the dyno we played with the timing in that zone, had one run that had zero breakup. Let it all cool down, and the next run with NOTHING touched broke up.
Right now I'm debating getting the msd digital box as per JD's recommendation earlier, but I still can't figure out what the box does different than the ext. coil. Regardless, I'm not concerned with understanding it, I just want to know if it'll clear it up?
WTF else to check??  ???
Re: The elusive answer to ignition breakup needed.
« Reply #1 on: October 05, 2009, 12:29:52 AM »
Sounds like your ignition input is shitty. I suspect poor factory wiring is part of the problem. Does the coil get +12V from the same wire as the ignitor? I'd try running a new wire from the battery through a relay to the ignition components.
« Reply #2 on: October 05, 2009, 12:47:08 AM »
The new ext. coil is simply hooked up to the wiring inside the dist. from the stock coil. So, you're saying to check the voltage at the stock harness connector to make sure of 12v?
hotrex
« Reply #3 on: October 05, 2009, 08:35:19 AM »
plug wires.  my car was doing tne same sit on the dyno.  canged the nwires and it was fine
« Reply #4 on: October 05, 2009, 11:40:17 AM »
Yeah, but you need to check the voltage at the ignitor and at the coil when it cuts out, to see if there's a correlation between low voltage and it cutting out. Be easier to just run a couple new wires and see if that fixes it. Nothing else it will surely help as factory wiring is probably puny.
« Reply #5 on: October 05, 2009, 01:50:19 PM »
grounds? JDMers would ALWAYS add grounds to hp vehicles for this specific reason.
« Reply #6 on: October 05, 2009, 02:36:35 PM »
 x10,    i have cars on stock dizzys making 600+.  The iridiums work great,  if it were a spark energy problem you would have noticed a difference with them.
  How old is your fuel filter???
« Reply #7 on: October 05, 2009, 03:20:16 PM »
I've changed the wires as well. From brand new napa brand to ngk wires. Nothing.
I've got all new -6 fuel lines with one 100 micron aftermarket filter. I don't think fuel is the issue.
That's what I'm about to do. Hopefully that fixes it because the next step is the digital box, and if I spend that kind of funds and it does nothing I'm gonna punch hotrex's baby mama.
« Reply #8 on: October 05, 2009, 03:24:29 PM »
hate crimes on tranvestites are becoming out of control.
kgx
  • MR2fag
« Reply #9 on: October 06, 2009, 07:15:04 PM »
leakdown test? i've seen motors with blown headgaskets that didn't overheat, but misfired badly under higher load. new HG solved the problem. last ditch effort probably...
« Reply #10 on: October 06, 2009, 09:11:22 PM »
Well, made a new harness for the distributor and hard wired it to the ecu. Once this bitch ass rain lets up I'll be able to test it out.
Zeniceguycrx
« Reply #11 on: October 06, 2009, 11:23:14 PM »
eye on fuel pressure in that range?  If its even droping a couple of psi it could fuck with the tune
power wires to the pump?
High boost right?  You could have an injector going out or even some shit in the tip fucking up spray.
If you can graph the injector wave forms for all four injectors during brake up we can tell whats going on from there.
Also if you can graph the secondary ignition that could also tell us somthing aswell
if you look at the firing lines you can tell a lot!
You can also use a low amp current probe on the coil to check for even dwell time and a few other things
The 30psi king of rice
« Reply #12 on: October 07, 2009, 02:07:51 AM »
Well, I took it out, and just like the external coil it seems to be running stronger up top, but still breaking up. My rev limiter is also much more defined now.  ??? The limiter sounds like anti-lag.
I think I may focus on the fuel side of things. I've been told that I'm about at the end with 1 walbro, 1000cc, E85, and 402hp. An inline helper is what was suggested, I've just got to locate one and strap that on. It can't hurt, and it can't cost that much either. (I hope)
« Reply #13 on: October 07, 2009, 09:09:29 AM »
If you want a cheap booster pump, pick up a bosch 044, off a CIS VW.
« Reply #14 on: October 07, 2009, 09:26:43 AM »
seen higher dyno numbers on E85 and a walbro/1000s.
you have stock wiring to the pump?!?! run some relay 10g off the battery to the pump.
which walbro do you have? real one? 255 or 255hp?
« Reply #15 on: October 07, 2009, 10:25:31 AM »
By hard wired it to the ECU, do you mean you ran a couple new heavy gauge fused wires through a relay or switch so that the ignitor and coil get solid clean power?
« Reply #16 on: October 07, 2009, 11:28:47 AM »
+1 these work great.
« Reply #17 on: October 07, 2009, 11:53:02 AM »
x10
I didnt realize your were on e85, i've got a bunch of customers running it, and ALL of them have had to change the fuel filter out twice.  One of the cars actually started to do the exact same thing as yours, it would surge/buck, felt like an  ignition issue.
« Reply #18 on: October 07, 2009, 12:14:21 PM »
If he suspects it's a fuel supply issue, he could simply Tee in a gauge and watch it on the dyno.
« Reply #19 on: October 07, 2009, 12:26:27 PM »
what kind of vw is that?
« Reply #20 on: October 07, 2009, 01:20:28 PM »
Rabbit, Jetta, Golf's, Passats,  Early 8v's anything with a 16v, ect...
Edit: Some volovo's, audi's, ect...
« Last Edit: October 07, 2009, 01:26:59 PM by dvst8r »
« Reply #21 on: October 07, 2009, 01:26:50 PM »
The new dist. harness was simply made using a cut up harness. All the same thickness wires as stock, but known to be run well. My walbro is the 255lph hp.
I originally had the fuel pump hard wired to the battery with thicker wires through a relay, but in the early stages of getting it started we had wire issues and I replaced everything with a different stock harness. I still have the relay setup, so I'll try that too.
My fuel filter is an inline aftermarket job under the car with AN fittings on it, so it won't be difficult to take that off and reverse clean it. I'll do that too.
My fuel rail has a gauge on it, but I never paid attention to it on the dyno.
hotrex
« Reply #22 on: October 07, 2009, 01:32:28 PM »
i think u need to feed ur old lady some cheap alcohol and have her spray pussy juice into your engine bay...  last ditch effort
Zeniceguycrx
« Reply #23 on: October 07, 2009, 01:57:17 PM »
the ricer says check fuel press   :yes:
« Reply #24 on: October 07, 2009, 02:16:18 PM »
pull it out and see how well you can blow through it, you should be able to blow through it with w/o restriction, I wouldn't fuck with trying to clean it,  filters for those things are like 15 bucks.
Zeniceguycrx
« Reply #25 on: October 07, 2009, 02:19:52 PM »
400hp on e85 is a fuel pump trying to feed 800hp on  a gas engine
« Reply #26 on: October 07, 2009, 02:25:31 PM »
its more like 520hp
from the many e85 cars i've ive tuned, takes ~30% more fuel for e85, ~40% more for e98
« Last Edit: October 07, 2009, 02:30:10 PM by sewell94 »
« Reply #27 on: October 07, 2009, 02:48:21 PM »
  This filter is 100 micron, and from looking through it when I got it, it looks like just a screen, so it should be easy to clean it.
« Reply #28 on: October 07, 2009, 09:07:58 PM »
run a direct 10g wire off the battery (fused) relayed from the stock wiring, along with a solid ground. ill bet that is the issue.
also the Bosch 044 pump did NOT come stock on a VW...
« Reply #29 on: October 07, 2009, 11:39:19 PM »
Please enlighten us to what is stock on a CIS vw then?
The ones I have taken off magically seem to support 700hp...
