Author Topic: Manual lathe?  (Read 11683 times)
NoPistons!
Manual lathe?
« on: October 16, 2009, 05:21:37 AM »
Thinking about getting one and converting it to cnc.....
http://www.dakeng.com/CNCconvert.html
hmt style.
How much should i spend for a standard bench lathe.  I dont think i'll be doing a whole lot of metal work but will probably get into that eventually.  I'm going to start making bushings and whatnot.
chronic
Re: Manual lathe?
« Reply #1 on: October 16, 2009, 08:51:12 AM »
Price varies on size and options substantially. I have a mini lathe that I got for 650. The lathe has a 7" swing, 1/2hp, its very small. But good for like you said, little bushings and shit.
The next size up is double the price, but for good reason. 10" swing, 3/4 hp motor, geared spindle vs variable speed controller.
You're going to have to look at what guys generally convert. Which machines have the most potential with a good sturdy frame, a good bed design, work capabilities. The one he has on that site, I dont know that I would try and convert that to an nc. Its a very cheap lathe(I have one similar to that), but I guess if you have the time and you're willing the work out the little quarks before you start the conversion. Then fuck yeah.
Sorry I haven't really told you anything. But that is where i would start, kind of go by what you want out of the machine, then look for one that will accompany it the easiest.
« Last Edit: October 16, 2009, 09:11:28 AM by chronic »
Re: Manual lathe?
« Reply #2 on: October 16, 2009, 11:23:00 AM »
The 7" china lathes are good if you want to spend some time (is also a great learning experience) using the lather to fix it's own design problems.  They are portable as hell and once gone through do a very good job on anything that fits in the chuck or across the bed.
The "double the price" asian lathes are kinda fucking crappy, a lot have the belt drive running the spindle directly (instead of via an intermediate shaft that gear drives it, a la the 7" asians and ALL of the quality non-asian lathes) which puts a lot of sideload on the bearings.  Worn bearings and snapped drive belts are common with them.  For anything bigger than the 7" china, go with a REAL lathe.  Expect to spend $1000+, but the nice thing about going that route is you usually get a pile of tooling thrown into the deal, which is where the $$$$ in machining is really at.
blackoutmp5
Re: Manual lathe?
« Reply #3 on: October 17, 2009, 08:41:54 PM »
I don't know your price range, but you can find used cnc lathes for dirt cheap sometimes. We got one at the shop for 2800..its a 1983 mazak that had a few minor fixes, and it runs almost as good as new. But once again I don't know your price range, but I would keep a look out on craigslist and ebay for local stuff.
True story. nbspnbsp Sleep eight hours, wake up craving dick. nbspnbsp Fucking liberal faggots.
