Author Topic: lol... is my wagovan broken?  (Read 19895 times)
« on: October 22, 2009, 09:47:29 PM »
so my wagovan is a piece of shit.
on the way home today i was noticing its serious lack of wanting to go into gear. from a dig, and on a roll. get it into gear it would make an odd ass noise. probaly a little grind going in. then make another probably squeeking noise releasing the clutch...
i got home took a peak underneath to see if it was spitting out pieces of clutch or something cool, doenst look like it. i spun the adjuster on the clutch cable down some to get some more tension on it. clutch pedel feels better now. seemed like it made it all better, down the driveway all good, out on the street good, 2nd gear, third? same shit. then didnt wanna go into second, funny noise on start in 1st when turning around...
so wtf? is my clutch done for or something? never had this shit before. doesnt seem to slip at all, like yesterday went all the way to redline no issues, got enough grab on the clutch to shake the shit out off the motor/dash... but im gonna guess its hitting the rivets and thats what im experiencing??
90turboteg
  • Rebuildin turbos
Re: lol... is my wagovan broken?
« Reply #1 on: October 22, 2009, 10:01:06 PM »
not 100% sure but my car had the same symptoms when my rivets that hold the hub plate to the clutch sheered off, car would make a funny noise letting the pedal out and kinda jerked, but the clutch didn't slip at all. then i was driving down the freeway and it just stopped moving, found my rivets were put in by a blind 6 year old Chinese kid that welds ssac manifolds without a helmet. but also my trans input shaft bearing makes a loud squealing noise because its fucked but only when my pedal is out and in 5th. so its something with the clutch most likely. i have a Chinese zoom 6 puck unsprung from the summit catalog, fucking works good now that i tap and died the basplate and put grade 8 bolts thew it then cut the bolts down and tig welded them to the plate lol O0
« Reply #2 on: October 22, 2009, 10:22:19 PM »
Broken shift fork.
90turboteg
  • Rebuildin turbos
« Reply #3 on: October 22, 2009, 10:29:07 PM »
Broken shift fork.
i 2nd that, it is a d series trans, u can break a shiftfork looking at it, i have a cg trans much stronger :P
« Reply #4 on: October 23, 2009, 12:31:35 AM »
Broken shift fork.
my first thought as well
« Reply #5 on: October 23, 2009, 12:41:54 AM »
clutch spit a spring
« Reply #6 on: October 23, 2009, 05:56:26 AM »
This. My wife's Del Sol had the same symptoms. The disc threw a spring.
« Reply #7 on: October 23, 2009, 09:20:11 AM »
umm... shit how driveable is it?? like my R has a couple days (week or so, lol) before its driveable. so i have no garage room, its raining, and no money to fix it.
« Reply #8 on: October 23, 2009, 10:47:28 AM »
If it's partially stuck out, and not completely free, I've had luck getting them to pop back in.  They pop out again, but you can maybe milk it for 50 extra miles before clutchtime.
« Reply #9 on: October 23, 2009, 11:27:31 AM »
well that was just an interesting 25 of those miles threw traffic  :?: hope there is about 75 more in it... gotta work saturday lol...
« Reply #10 on: October 23, 2009, 04:34:43 PM »
My teg spit a spring one time i dropped the trans and pulled it out and slapped it all back together and it was fine for a quite awhile until i swapped the clutch.
« Reply #11 on: October 23, 2009, 04:44:06 PM »
well i struck a deal with a tech at work. gonna chip his PM6 and give him 4 14" steelies my buddy left at my place, for the labor. cheap A/M clutch threw work is like 106bucks (90-91) and matching flywheel is 45... so thats not too bad... just cant do it till next week, didnt sound like he had the time... shit...
whats the worst that can happen? lol
Ravage70
« Reply #12 on: October 23, 2009, 11:47:44 PM »
you ---> biking
« Reply #13 on: October 24, 2009, 02:31:20 AM »
I got 4000 miles after fixing one, and only because it got oil on it some fucking how. Slipped above 2psi, and anytime in 5th.
On mine there was enough metal on the tabs to probably use it a few thousand on hope and a prayer. Took some thicker sheet metal, welded on new tabs, and she was good to go. It had rounded the outside edges of the crank bolts before I fixed it. :?:
Jordy53
« Reply #14 on: October 29, 2009, 09:30:02 AM »
One time my buddy had this problem on his CRX and after I pulled the tranny I figured out that the plastic around the clutch cable had broke and nothing was holding it to the fire wall. Just a thought
« Last Edit: October 29, 2009, 03:07:52 PM by Jordy53 »
You cannot help the poor by destroying the rich. You cannot strengthen the weak by weakening the strong. You cannot build character and courage by taking away men'#39#39s initiative and independence. You cannot help men permanently by doing for them what they could and should do for themselves.
Random Hero
« Reply #15 on: October 29, 2009, 02:32:27 PM »
I just did a clutch last month with this problem. all 4 springs had fallen half way out. and a piece of the metal that holds the spring in was stuck between the friction surfaces.
« Reply #16 on: November 03, 2009, 03:25:12 AM »
I had this happen on my prelude, I drove it longer then i probably should have. The spring poped out and fucked the flywheel bolts up so you wouldnt be able to get them off. I slammed a new disc in and sold the car  :noel:
« Reply #17 on: November 05, 2009, 05:40:57 PM »
i got a wagovan forsale/trade btw  :?:
still driving it lol... having issues with getting my other car on the road still. it might get its own post tonight.
i will most likely be replacing the clutch and flywheel for 90-91 bigger pieces.
« Reply #18 on: November 05, 2009, 07:04:25 PM »
$100
« Reply #19 on: November 05, 2009, 07:34:06 PM »
for you $2000...
