Author Topic: junk yard exhaust  (Read 7045 times)
junk yard exhaust
« on: October 28, 2009, 08:09:28 AM »
found this dodge ram cummins diesel exhaust resonator for $25.. I figure it muffles the 6.7L turbo diesel, so it should work ok on a little honda motor. usually I've just ran open downpipe, but since I went 3", the sound is unbearable.
it's 3" in 4" out
do you guys think it will work alright?  I had a guy who gives pretty good advice say it's not worth the work because the cummins diesel most likely beat the shit out of it, and it will be clogged full of soot.
Re: junk yard exhaust
« Reply #1 on: October 28, 2009, 08:22:42 AM »
my anti-lag in crome pro scares people.. i'm sure that would work  :noel:
salesmonkey
« Reply #2 on: October 28, 2009, 09:35:25 AM »
i was kinda wondering the same thing sense i would see these all the time at the scrap yard. not really the clogged thing but just how it would turn out.
rhmt for life
« Reply #3 on: October 28, 2009, 09:47:18 AM »
i'm going to try it and update this thread with results
« Reply #4 on: October 28, 2009, 10:42:13 AM »
concrete drill bits uber long do the trick when hollowing out cats.  i've never played with one of those resonators but you could do the same
« Reply #5 on: October 28, 2009, 10:57:22 AM »
resonators are usually a straight through design with a baffle.. no modification needed
« Reply #6 on: October 28, 2009, 11:09:55 AM »
what i was thinking.....    i don't see how could they get clogged?
« Reply #7 on: October 28, 2009, 02:54:11 PM »
Most newer trucks have a device I forgort the name of. Unless the guy removed it or it failed, it shouldn't be clogged. It collects all soot from the exhaust just after the header(s), then the ecu basicly heats the EGT's enough to burn all soot out everywhere. You can literally ignite leaves with the heat if you remove the stock vented exhaust tip.
« Reply #8 on: October 28, 2009, 04:16:25 PM »
Are you talking about the "afterburner"? It's there to clean out the cat, and kicks on every so often. It's just a flamethrower type setup in the exhaust. Fucking emmissions...forcing people to over engineer too much shit really
« Reply #9 on: October 28, 2009, 05:33:58 PM »
the particulate filter thats now required on all diesels?  dont' know much about how they work tho
« Reply #10 on: October 28, 2009, 05:59:25 PM »
if you want to clean it out buy couple cans of carb cleaner and hit up the local car wash
less than 5 bucks and it should be damn near spotless afterwards
toyolla86
« Reply #11 on: October 28, 2009, 07:45:32 PM »
you should fill it with gasoline to get the biggest and best backfire ever
twin50 son. get some
and stop acting like a muslim
salesmonkey
« Reply #12 on: October 29, 2009, 07:42:23 AM »
haha that sounds fun pictures and videos as well. get a gallon size zip lock bag and fill it full of gas and toss her in there. once it ignites let the fun begin haha.
rhmt for life
