Author Topic: MY build thread repost  (Read 6157 times)
rudebwoy
  • tripple OG
« on: October 29, 2009, 10:26:51 AM »
I made this thread before but got lost because of the forum wars. here goes again.
1999 HONDA CIVIC HATCH, (German specs goal 600whp)
HEAD:
*B16A2 Cylinder head
*Crower valves springs, and retainers
*Crower stage 2 turbo cams
*Golden Eagle 84mm Headgasket
*Golden Eagle adjustable cam gears
*JG edelbrock intake manifold
*JG edelbrock 65mm throttle body
BLOCK:
*Golden Eagle sleeved B20 block
*Manley turbo tuff rods
*Arias 84mm 9.15.1 compression pistons
*Arp main studs
*Arp head studs
*Gsr main Girldle
*ACL Race main bearings
*ACL Race rod bearings
*Moroso street and strip oil pan
*T1 Racing development catch can/modified valve cover
TRANSMISSION:
*B16a2 S4C
*LS B18 5TH Gear
*Gearspeed carbon synchros
*Mfactory Helical LSD
*DSS 2.9 axles
*Competition twin disc clutch
SUSPENSION/WHEELS/TIRES/BRAKES:
*Ksport full coilovers
*Avid aluminum torque mounts
*Prothane motor mount bushings
*Pothane Shifter bushings
*B&M Short shifter
*EDT front traction bar
*ASR Rear sway bar and subframe bar
*BLOX front and rear camber kits
*BLOX toe in/out adjusters
*BLOX rear control arms
*Rear eb strut bar
*Password JDM front 3 point strut bar
*Nippon F2 16" /yokahama
*M&H racemasters/ 15" kosei k1
*NSX 11.1 front brake conversion
*RSX 10.2" Rear brake conversion
*Goodrich SS brake lines
*Blox extended wheel studs/nuts
TURBOCHARGER
*Garrett T04R big kahuna(T67HO)
*Blox Velocity Stack
*Peak boost Topmount manifold
*Tial 44mm wastegate/open dump
*Tial 50mm BOV
*Apexi Turbo timer
*Hondata boost controller PWM kit with MAC boost valve
*3" downpipe
*QTP E-cuotut
*Magnaflow cat/3" test pipe
*Kteller 3" catback
*2.5" Peak boost charge piping
*CX racing bar and plate 700hp FMIC
*CX racing engine oil cooler
*Nitrous Xpress Ntercooler sprayer
*CX racing aluminum radiator
*Flexa lite Fan
FUEL/ENGINE MANAGEMENT/IGNITION/MSC ELECTRONICS:
*Precision 1600cc peak and hold injectors
*FJO peak&hold injector driver
*Edelbrock fuel rail
*Russel inline fuel filter
*8AN feed SS line
*6AN return SS line
*Fullblown motorsports dual fuel pump hanger
*2 Walbro 255lph HP fuel pumps
*Aeromotive fuel pressure regulator
*Hondata s300 EMS
*Zeitronix wideband with display, integrated AFR, Egt, boost gauge.
*AEM 3.5 bar map sensors one for map, and one for boost signal
*Devil's own progressive methanol injection
*MSD digital 6
*MSD HVC coil
*MSD modified cap /honda distributor/
*NGK 8mm wires
INTERIOR GAUGE/ DISPLAY
*EK9 Recaro seats (red)
*EK9 rear seat
*EK9 door panels
*EK9 type R headlights
*EK9 Momo steering wheel
*Sabelt 3" camlock harness
*TDA harness bar
*Autometer Carbon fiber oil pressure gauge
*Autometer carbon fiber water temperature gauge
*Autometer Pro adjustable shift light with Rpm
*2000 civic SI cluster
*Zeitronix display
*Kenwood CD player
APPEARANCE/AERO AND COSMETICS:
*Type R front lip
*Type R rear lip
*Type R grill
*Type R wing
*Spoon style power mirrors
*Password JDM cooling plate
*password JDM radiator stay
 have at more pics upload is time consuming.
old ride
« Last Edit: January 27, 2010, 05:27:37 PM by rudebwoy »
2000 civic SI daily driver
98redcavz24
  • NE Crew
Re: MY build thread repost
« Reply #1 on: October 29, 2009, 12:27:43 PM »
solid as usual. clean as fuck too thats JDM
you need to change your custom title to "autobahn assassin"
« Reply #2 on: October 29, 2009, 12:42:22 PM »
got enough money in the setup?? if you didn't buy a house before this, i'd call you foolish.
« Reply #3 on: October 29, 2009, 03:40:22 PM »
Just because your broke doesnt mean spending money is bad.
« Reply #4 on: October 29, 2009, 04:12:17 PM »
Nice shit as always!
« Reply #5 on: October 29, 2009, 04:41:16 PM »
i like your setup clean ride
boosted 00 black si
« Reply #6 on: October 31, 2009, 03:22:17 AM »
nice build man  O0
go fuck your self
BORN TO BOOST
LITTLE B16.400whp on 16psi
rudebwoy
  • tripple OG
« Reply #7 on: October 31, 2009, 11:08:01 AM »
thanks ya'll. now tag that shit in the project section.
« Reply #8 on: October 31, 2009, 10:56:34 PM »
$ Nice build $
« Reply #9 on: November 01, 2009, 01:28:20 AM »
damn, thats a clean build.  Nice upgrade from the old car.
