Author Topic: crank for a y7  (Read 12523 times)
sleepingciv
  • BANNED
crank for a y7
« on: October 29, 2009, 10:57:47 PM »
can i use any 1.6 sohc crank in a y7??
zc a6 z6 y8
theidealone
Re: crank for a y7
« Reply #1 on: October 30, 2009, 02:34:55 PM »
As long as its got the same snout size. I am using a Z6 crank in my ZC, and Im about to use another Z6 crank in an A6.
theidealone
Re: crank for a y7
« Reply #2 on: October 30, 2009, 06:03:38 PM »
Should only be 2 sizes. 22 or 24mm.
Re: crank for a y7
« Reply #3 on: October 30, 2009, 07:20:49 PM »
sleepingciv
  • BANNED
Re: crank for a y7
« Reply #4 on: November 03, 2009, 08:26:36 PM »
thanks guys
and im pretty sure the smaller snout was only in the 1988 motors
Re: crank for a y7
« Reply #5 on: November 04, 2009, 01:34:17 AM »
does a zc crank fit in a y block?
yes, so will the z6/a6/a1, although as stated above early '88 a6 cranks had a smaller snout and IIRC some differences in cam gears. also the 86-87 dohc motors had a smaller snout as well, while the 88-89 were the large snout. i have to do some research to make sure this is 100% correct, but i believe it is
