Author Topic: 94 Integra Fuel Pump In A 93 Integra?  (Read 45572 times)
G2 Racer
« on: March 14, 2009, 05:50:33 PM »
Someone wants to trade me a Walbro 255lph pump kit for some parts I'm selling.
The part number come up for 92-01 Integras and 92-00 Civics. Can I use this pump in my car or no?
Re: 94 Integra Fuel Pump In A 93 Integra?
« Reply #1 on: March 14, 2009, 06:10:05 PM »
I've heard that the obd0 pumps won't work with obd1/2 vehicles and vice versa.
G2 Racer
« Reply #2 on: March 14, 2009, 06:45:12 PM »
92-95 is ODB1 so.....
BoostForLife
« Reply #3 on: March 14, 2009, 06:58:02 PM »
look up the part numbers with walbro
GS-341 and GS-342 i believe are different, but 98% identical.
Doesn't matter though, i used to run a GS-341 in my del sol (required GS-342), it worked great. The only differnce between them is the fuel hose is a little bit off, but not enough to affect anything.
walter
« Reply #4 on: March 14, 2009, 07:24:21 PM »
what is the reason is pump just receive current from ECU and ground?  ???
« Reply #5 on: March 15, 2009, 02:35:07 AM »
Its the whole tank plug thing that holds the pump/tubes/wires that won't swap. The older cars - I'll just say cable trans cars - usually have a more vertical pump orientation, so the newer filter bag can't be used (kit or stock baggie).
The only difference between the pumps is the location of the inlet & outlet. The outlet ends up being off by 1/2", but the rubber patch hose they use can deal with that offset. The plugs might be different tho, my EF kit came with a plug pigtail - I never got around to installing it.
