Pages: 1 [2] 3   Go Down
Author Topic: "Best" Stock FWD 4 Cylinder Engine/Transmission Combo  (Read 50674 times)
Re: "Best" Stock FWD 4 Cylinder Engine/Transmission Combo
« Reply #30 on: November 02, 2009, 10:00:25 PM »
LG0
W41
 ;D
« Reply #31 on: November 02, 2009, 10:04:28 PM »
460 BBF
« Reply #32 on: November 02, 2009, 10:05:55 PM »
400M
« Reply #33 on: November 02, 2009, 10:11:03 PM »
just plugging what I run.   4AGE supercharged.  20v blacktop if emissions and shit isnt an issue  Both about 160hp stock
as said earlier you will want more
« Reply #35 on: November 02, 2009, 10:23:33 PM »
Geo 3cyl
« Reply #36 on: November 02, 2009, 10:27:07 PM »
Geo 3cyl
BBG(Big Block Geo)  AKA Geo 4 cylinder.
hotrex
« Reply #37 on: November 02, 2009, 10:37:56 PM »
sl-c with turbo j32a swap
« Reply #38 on: November 02, 2009, 10:49:55 PM »
3sgte.
« Reply #39 on: November 02, 2009, 10:51:51 PM »
Geo 3cyl
You mean G13B.  Learn your Suzukis.
« Reply #40 on: November 02, 2009, 10:52:39 PM »
if I cared sir...
« Reply #41 on: November 02, 2009, 10:53:02 PM »
b20vtech
« Reply #42 on: November 02, 2009, 10:55:38 PM »
if I cared sir...
They were the original engine to get the Vitara pistons swapped in, sir.  Not many otherwise stock 1.3 liters will eat 400 whp of boost with a (cast) piston swap.
« Reply #43 on: November 02, 2009, 10:59:42 PM »
ok
« Reply #44 on: November 02, 2009, 11:01:03 PM »
FUCK YOU I am so beating you up this weekend.
« Reply #45 on: November 02, 2009, 11:03:23 PM »
I'll fart on your couch...  I'll only be there Friday night
bigwig
« Reply #46 on: November 02, 2009, 11:11:49 PM »
Massive Response:
-D16 turbo setup would be pretty awful compared to a OEM B-series high compression build or K-series.  No matter what you would do, the power band would be a bit too violent and would place power in the wrong places.  I know they are inexpensive and work, but I just can't see myself getting persuaded to go that route.  That faggot Bisi would have to volunteer to build me some magical D-series for pennies for me to think about going that route.
-Yes, you can make it street legal in most states.  You have to call the DMV and ask for a packet of information on how to title a kit or custom car.  Then follow the protocol.  Most states want the standard stuff: lights, windshield, wipers, indicators, ect.  You need engine documentation.  Depending on state, you may or not need SMOG crap.
-I will never put a centrifugal SC on anything, ever.  Twin Screw>Roots>Centrifugal.  I do have some fears with the K-series faggot transmissions.  They aren't cheap enough to break often.
-If I'm buying overpriced engines, I'm buying Honda garbage.  If someone gave me a free VW engine if I promised to use it in this vehicle, I'd have to mull it over.
-Shadow, you're retarded.
-B16 is faggot shit no matter how you figure it.  If I went B-series, I would only go 1.8L or bigger.
-fysh, as much as I like that idea, I also like the idea of having an open engine bay.  Throwing a V8 in with the matching transmission would probably fit, but then I'm cramped.  I hate working on tight engine bays.  4 cylinder option is really just for the ease of fitment/working.
-Has to be 4 cylinders for all of you others suggesting larger or less than.
hotrex
« Reply #47 on: November 02, 2009, 11:19:25 PM »
gsxr1000 mmm squential tranny
« Reply #48 on: November 02, 2009, 11:24:44 PM »
Turbo Hayabusa. I mean I'm still partial to a 225whp 380ft.lbs TDI, but I know it's not everyones thing, the turbo busa is a close second.
« Reply #49 on: November 02, 2009, 11:29:56 PM »
Geo 3cyl
I have enough on my plate to learn, sir.  Suzuki engine codes are about item number 0389453095304987 on the list.
Eggylshatch
  • Pen15 Club President
« Reply #50 on: November 03, 2009, 12:19:12 AM »
Who has the video of the smart car with the 'busa engine?  That is the most gangstur shit, ever, right after tprc and the doube d's and crx2000 in progress
« Reply #51 on: November 03, 2009, 08:12:10 PM »
Cummins 4BT
« Reply #52 on: November 03, 2009, 08:30:54 PM »
« Reply #53 on: November 03, 2009, 09:09:21 PM »
I know you said stick to 4 bangers, but what about a 6 cyl? You could work with it reasonable enough, and the vq is a pretty nice motor stock, readily supported, responds to mods great and they are tough as nails. They have a great usable powerband too. It may just be a little TOO much down low.
   Any pics or drawings of the chassis?
« Reply #54 on: November 03, 2009, 09:33:19 PM »
vr6... 4 cyl dimensions with displacement!
Overrated from what I am told on here...
« Reply #55 on: November 03, 2009, 09:48:32 PM »
QFT.
« Reply #56 on: November 03, 2009, 10:16:42 PM »
SHO 3.2 Yamaha V6.  Swap in a set of MTX cams, and use the MTX-IV manual 5 speed trans axle.
With such a lightweight car, the trans-axle ought to survive the punishment just fine.
 ;D
fysh
« Reply #57 on: November 03, 2009, 11:02:09 PM »
Go big or go home, right?
Turbocharged 5.2L I4
Isuzu 4HK1-TC
« Reply #58 on: November 03, 2009, 11:12:55 PM »
QFT.
Not overrated when you breathe on them.  It's not just that they make 500+ on a stock engine, they also make enough torque to scare an H22.
« Reply #59 on: November 03, 2009, 11:15:22 PM »
QFT.
Nonsense.  VR6 == trash apparently....
Pages: 1 [2] 3   Go Up
