Author Topic: Vacuum Issue??? NSFW!!!  (Read 13409 times)
FreshDA9
« on: November 07, 2009, 01:57:01 PM »
Ok just started up a map with BRE in a PR3 ecu. the problem is at idle it is sitting at 16-14 inch vacuum. i can not get it to sit in 23 or 21in.v... Also the distributor is all the way retarded if we set it to 16 degrees it will sit in 14-13in.v...
We have checked timing its on. We changed map sensors to a know working 1 nothing. changed ignition timing in the map still nothing??
The car is a 91 crx PR3 ecu with a B16a. stock map sensor, tps, also a distributor king dizzy. when he had this motor in his integra it would idle at about 37-35Kpa in ectune?
I tried to attach the maps but said i exceeded limit every time.
And for your effort i give you some Porn for my gratitude.......
« Last Edit: November 07, 2009, 02:11:18 PM by FreshDA9 »
JACER63
  • well shit..
Re: Vacuum Issue??? NSFW!!!
« Reply #1 on: November 07, 2009, 03:53:25 PM »
compression test to see if all cylinders are good?  could have a compression problem causing the low vacuum.
FreshDA9
« Reply #2 on: November 07, 2009, 04:35:25 PM »
Steady idle. will have him do a compression and leak down to confirm..
« Reply #3 on: November 08, 2009, 04:41:04 PM »
Last BRE car I did behaved similarly.
« Reply #4 on: November 08, 2009, 05:57:22 PM »
Mine was working well, but it was a OBD0 PR4.
FreshDA9
« Reply #5 on: November 08, 2009, 10:32:53 PM »
Really do you by chance know why? i got the map and a couple logs but RHMT keeps saying im exceeding the upload limit even if i try to upload just 1 that is way below the limit.
« Reply #6 on: November 09, 2009, 01:36:35 AM »
It was the second BRE car I've done, the other was ~4 years ago.  I really know jack shit.
FreshDA9
« Reply #7 on: November 09, 2009, 01:42:49 AM »
Damn... gotta be something simple im over looking.
« Reply #8 on: November 09, 2009, 01:47:44 AM »
Runs fine = runs fine.  What are you overlooking?
FreshDA9
« Reply #9 on: November 09, 2009, 01:57:22 AM »
Just seems to be running to low of vacuum at idle. thats what caught my attention.  that and the starting issue but that should be an easy fix.
Zeniceguycrx
« Reply #10 on: November 09, 2009, 01:58:52 AM »
thread jack
Iv been trying to get bre to run on my computer
Where did you get a copy from and anyone got a stock pr3 in for it?
The 30psi king of rice
Zeniceguycrx
« Reply #11 on: November 09, 2009, 01:59:39 AM »
I would dbl check you timing
it could cause low vac if a cam is out
« Reply #12 on: November 09, 2009, 02:01:05 AM »
Nope, low "vacuum" according to datalogs and cold start issues - mostly when in the 90-140 degree range after start - are what I experienced.
FreshDA9
« Reply #13 on: November 09, 2009, 02:13:58 AM »
Hmm good to know.. ok ill give it a shot and see how this ends up.
As far as BRE mr thread jacker try pgmfi.org
« Last Edit: November 09, 2009, 02:16:22 AM by FreshDA9 »
