Author Topic: CRX HF vs Si  (Read 12466 times)
stealthiskey
CRX HF vs Si
« on: November 12, 2009, 01:50:33 AM »
I'm in the market for a CRX for fun,
Wondering if I should opt for the 88-89 HF because it is the lightest of the gen 2s, or if the Si could be made equally light by removing sunroof, AC, etc.
The plan would be to build up a d16a6 or z6 motor for it, so getting an Si with a running a6 is attractive, but since I'm not pressed for time, would the HF be a better choice?
i <3 TeH CaCk!!!!
« Last Edit: November 12, 2009, 03:23:16 AM by ApexSilver06MR »
Re: CRX HF vs Si
« Reply #1 on: November 12, 2009, 04:17:41 AM »
88-89 HF, 1800 lbs, no stripping needed.
My 89 CRX HF is under 1800 lbs, radio and speakers were removed :(
Re: CRX HF vs Si
« Reply #2 on: November 12, 2009, 03:07:59 PM »
agreed
just buy the lighter car, they are cheaper anyways
stealthiskey
Re: CRX HF vs Si
« Reply #3 on: November 13, 2009, 02:20:40 AM »
I agree, but stripping is free, whereas if I get the HF then I gotta buy a d16 motor/trans.
If I removed all the bs from an Si (sunroof, AC, etc) would it weigh the same as the HF?
theidealone
Re: CRX HF vs Si
« Reply #4 on: November 13, 2009, 03:33:42 AM »
I wouldnt ruin an SI with the intentions of making it an HF... I kind regret gutting out my SI (Civic). Wish I would have done it to an STD or DX.
Just go with the lighter chassis (as stated), if youre concerned with weight. But its not like a CRX SI is all that heavy to begin with...
Re: CRX HF vs Si
« Reply #5 on: November 13, 2009, 05:25:49 AM »
Just do what I did, find the lucky car.
89 CRX HF, Si driveline, Teg rear brakes Koni's, ST bars, H&R springs, thickwall exhaust, DOHC ZC tranny with Quaife, 8 lb flywheel, 6 puck unsprung clutch......
Bought not built, but built like I would have.
Re: CRX HF vs Si
« Reply #6 on: November 13, 2009, 10:09:08 AM »
Agreed.
If there's a turbo strapped to this build, don't fucking worry about it and enjoy having a nice-ish car, ASSuming you don't start out with a Crapper McDaniels style CRX
Re: CRX HF vs Si
« Reply #7 on: November 13, 2009, 09:37:06 PM »
What kind is that?
Re: CRX HF vs Si
« Reply #8 on: November 14, 2009, 12:29:11 AM »
What kind is that?
Altezza lights were installed seven owners ago, none have seen fit to remove them.  Now visualize the condition of the rest of the vehicle.
boostinallday
Re: CRX HF vs Si
« Reply #9 on: November 15, 2009, 05:22:36 PM »
i love my si  stock ls  boosted 13.1
tj_camp09
  • N00B *Read Intro Sticky*
Re: CRX HF vs Si
« Reply #10 on: November 16, 2009, 10:21:44 PM »
i need help wit my wiring situation im planning on swappin the h22a into a crx is there a cheaper way out than buyin the rywire kit for 360? an is there a cheaper way to make axle for it other than hasport axle...?
