Author Topic: where to get banjo fittings that attach to mcmaster lines  (Read 43266 times)
7808
« on: March 18, 2009, 10:37:15 AM »
anyone know where to get cheap banjo fittings that could be used with mcmaster braided lines with the 1/8 ends? i think the size i need is for 10mm banjo
somthin like this, but im not sure what AN sizes
are what and those are like $16
Brake Banjo Fitting
-04 AN - 10mm Banjo Fitting
361-997641
Re: where to get banjo fittings that attach to mcmaster lines
« Reply #1 on: March 18, 2009, 11:20:06 AM »
10mm to -4an or -3an
Price: $22.99 PR
Speedwaymotor
http://www.speedwaymotors.com/BANJO-FITTING-3and8-or-10MM-to-AN,6468.html
Just go type in banjo in there search function. I have had great luck with there braided  lines. The best price around.
7808
« Reply #2 on: March 18, 2009, 02:18:25 PM »
that... is what i posted above, but yours cost more ..  so is -4 an  the same thread as 1/8 npt ?
« Reply #3 on: March 18, 2009, 02:51:17 PM »
$22.99 PR
= 2 of them of them
Or $11.495 Each  ;)
« Reply #4 on: March 18, 2009, 08:51:38 PM »
npt is thread seal an(-an) is standardized thread ranging, with a tapered seal at the end (comrpession fitting)
To clarify this a little more for someone that might not understand:
NPT is National Pipe Thread and is a tapered thread.  The outside diameter at the end of the thread is smaller than the outside diameter at the base of the thread, so it looks like a threaded cone.   The female mate is opposite ie the hole gets smaller the deeper it goes.  These types of seals it is good to use teflon tape or pipe dope.
AN has SAE or straight threads, like bolt outside diameter of the threads stay the same size from beginning to end.  The taper at the end of the fitting meets a matching taper inside the female part so seal, the threads have absolutely no effect on sealing aside from profiding holding force.  These fittings DO NOT need teflon tape or any kind of pipe dope (even though I see it every time I walk into a customer's plant  :P)
the number -4, -8 etc. is common sizing and it is the size in the number of sixteenths.  -4 = 4/16 or 1/4"  -8 = 8/16 or 1/2" etc.  This usually refers to the inside diameter of the hole, or id.  Except tubing then it refers to the outside diameter or OD.
I like those pictures though, good visual reference for pulling fittings out of a bin.
« Reply #5 on: March 18, 2009, 09:09:58 PM »
http://www.anplumbing.com/shop/index.php?shop=&dept=Banjos
Banjo Adapter -4 male to 10mm Hole diameter .425 height   $ 7.41
I am the winnar
