Author Topic: ac fan relays  (Read 45083 times)
notfastcrx
ac fan relays
« on: March 19, 2009, 02:30:46 PM »
hey i have a question about the ac fan relays and wires. since my ac was removed and i have all these god damned wires in the engine bay. is it kosher if i just cut them? or should i just run them into the car and hide them?
DreaMeR
Re: ac fan relays
« Reply #1 on: March 19, 2009, 02:46:18 PM »
run them somewhere, you'll cut the power to your entire fan control system. Dont cut them lol
Re: ac fan relays
« Reply #2 on: March 19, 2009, 02:53:59 PM »
or manually switch your fan on and off
MantisX
Re: ac fan relays
« Reply #3 on: March 19, 2009, 03:07:00 PM »
I just tied mine up and ziptied it away on the frame.
Re: ac fan relays
« Reply #4 on: March 19, 2009, 03:42:11 PM »
Go download read a Helm's manual and see how the wiring goes. Some can probably go, but most of the relays for AC & other stuff are outside in the engine bay.
AndrexXxo
Re: ac fan relays
« Reply #5 on: March 19, 2009, 06:59:25 PM »
if they come in the same harness just hide them, if the come in diff harness and connectors you should be fine cuting them, but RTFM (read the fucking manual) before you do anything
Re: ac fan relays
« Reply #6 on: March 20, 2009, 08:08:56 PM »
get some zip ties and some split loom, then do work
notfastcrx
Re: ac fan relays
« Reply #7 on: March 20, 2009, 11:54:38 PM »
fuck it. i just cut them, ran the cut end back through the engine bay so the relays are under the dash. and soldered them. problem solved.
