Author Topic: Help with crome basemap  (Read 59114 times)
snarf
« on: March 19, 2009, 07:40:40 PM »
    Hey guys, I just started to tune my car (b18b-450-t3/t04e).  Now I've been using a basemap called "ls-450's-t25-7lb " and it's been working great for my motor and turbo. My a/f ratios are 14ish and about 11.3 in 5 lbs of boost.  The only problem is when I turn up the boost to 10 lbs it's a bit lean 11.9-12.1.  All I want to do was richen it up a bit.
New her is my question after the changes I made the a/f ratio went up to 13.9-14.6.  No matter what I did I COULD NOT get the a/f ratio down.  I added more fuel and even had the timing down to 6 degrees and still got 13.8 to 14.3 a/f ratio at 10 psi.
I made the changes on my home PC and I must have changed the chip like twenty times.  Every time I made a change to the basemap the result was the same 14ish a/f ratios.  Please help
obd1 p75 with free crome
Dweezil
    • Michigan Civics
Re: Help with crome basemap
« Reply #1 on: March 19, 2009, 08:12:34 PM »
Have you disabled the O2 sensor and tried it that way?
« Reply #2 on: March 19, 2009, 08:23:16 PM »
Your fine with your afrs at 11.9-12.1 just go back to your basemap
« Reply #3 on: March 19, 2009, 08:43:47 PM »
+2
snarf
« Reply #4 on: March 20, 2009, 09:00:55 PM »
The O2 sensor is disabled!  Plus Its not even wired to my ecu.  The only part that's aftected is where I make my changes, the rest stays the same.  I remember a screan shot of a something called target a/f ratios but can't seam to find it in crome.
The only reason I wanted lower a/f ratios is becouse it gets up to 120+ in the summer here.
Thanks guys any futher help whould be apreciated.
« Last Edit: March 21, 2009, 12:24:33 PM by snarf »
Dweezil
    • Michigan Civics
« Reply #5 on: March 20, 2009, 09:05:49 PM »
Timing is more important than fuel with higher air temps. Just pull a degree or two to be safe.
« Reply #6 on: March 20, 2009, 09:54:50 PM »
are you using Crome free or pro crome pro has target afr its the green A type symble
snarf
« Reply #7 on: March 21, 2009, 12:27:41 PM »
crome free. I really want to be able to tune my own maps more than anything.  Has anyone ever had a similar problem?  Thanks guys
« Reply #8 on: March 21, 2009, 12:41:31 PM »
What version of crome are you using?
snarf
« Reply #9 on: March 21, 2009, 12:45:18 PM »
1.5.0
turbo4life
« Reply #10 on: March 22, 2009, 03:55:21 AM »
return to your previous setting 11.9 12.1 is perfect reduce the timing a touch.. *higher air temperatur*  :evil: knock
End the fake food.
« Reply #11 on: March 22, 2009, 08:24:18 PM »
so you were at 11.9-12.1 at 10psi, then you added fuel and now it's even leaner?  :?:
snarf
« Reply #12 on: March 25, 2009, 06:44:59 PM »
Yea, must be something wrong with crome since no one else has had this problem.  I'll try to reinstall it and make my own basemap.  I'll let you guys know when I fix it.
