Author Topic: Weird thing happened tonight  (Read 13161 times)
« on: November 22, 2009, 12:56:57 AM »
I was driving on the highway and I heard clicking sound in the dash and the engine missfired. I had a CEL at one time, but after a restart the cel was gone. Did that 2-3 times.
I think the sound was comming from the main relay... What can cause the main relay to act like that? I'm not sure if the problem could be related to the recent installation of eCtune, but I never had problem before.
Also, the thing was happening on ~20-30% throttle only.
It was my first "long" ride on the highway since I installed eCtune so I don't know if it's related to it.
If someone had similar problem...
I know JD doesnt like direct pics in his section so here are some nws pics:
http://www.kinkygfs.com/galleries/kinkygfs-131/index.php?nats=Ni41LjMuNC4wLjIzMi4wLjA
Re: Weird thing happened tonight
« Reply #1 on: November 22, 2009, 02:43:44 AM »
mine has never done that.
i suspect you are doing something wrong.  :)
« Reply #2 on: November 22, 2009, 03:01:34 AM »
Resolder the joints on the main relay just to be sure. Only takes 5 minutes.
« Reply #3 on: November 22, 2009, 04:37:37 AM »
Ground, a nice thing to stand on.
« Reply #4 on: November 22, 2009, 10:45:52 AM »
Might be a ground. I don't drive this car very often. Things are rusting fast.
I'll solder the joints in the main relay to see if it helps too.
lilpooh21186
« Reply #5 on: November 22, 2009, 03:35:15 PM »
with my hatch pin d1 went bad white/blue i belive my car would randomly die found it to be the power to the ecu from main relay.
Ecu chipping
basmaps
Adam Hopkins
  • Peyton Manning
« Reply #6 on: November 23, 2009, 03:33:32 AM »
Ground, T-stat housing. Or maybe your main engine ground.
« Reply #7 on: November 23, 2009, 05:59:31 PM »
are you using an ostrich with ectune?
if so, it is probably your cable. i have had that happen from the cable being loose. thats what i hate about ectune. if you have a chip, you cant retune as you want and if you want to be able to tune it, you have to have an ostrich or demon. i like to have a chip in my car when driving normally
« Reply #8 on: November 23, 2009, 11:34:36 PM »
Yeah, ostrich + ectune. I don't really care about chip, I like ostrich. I'll check the cable tomorrow.
Did it a lot this morning too. I'll check it out all your inputs thursday when I have some free time. Thanks guys!
« Last Edit: November 23, 2009, 11:36:32 PM by Teg2boo »
D.Alomb
  • [url=http://tierussianwoman.w-ru.com/]largest dating sites[/url]
    • iwantu
« Reply #9 on: November 29, 2009, 02:59:57 AM »
You are overthinking it... your rod isnt bending. Your rod bearing might not be too happy the weird rpm related noise, but the rod isnt physically bending
latest dating site
« Reply #10 on: November 29, 2009, 03:04:15 AM »
Wrong website. Try again.
« Reply #11 on: November 30, 2009, 10:17:42 AM »
You keep making mis-posts on this forum.  What's up with that?
« Reply #12 on: November 30, 2009, 10:53:23 AM »
LOL
What the?
« Reply #13 on: December 03, 2009, 07:17:24 AM »
Best troll ever or best troll ever?
« Reply #14 on: December 03, 2009, 10:23:16 AM »
No, he just posted asking for help in an RX7 thread.  That, and the website in his profile, explains it all.
