Author Topic: Recent Cage  (Read 70190 times)
Re: Recent Cage
« Reply #30 on: March 28, 2009, 04:00:33 PM »
However, citing you need a fucking oven to bake your shit to normalixe a cage on a site called realhomemadeturbo seems, well... Morinic... Or at least... WAY out of scope. It will be finme is all I saiud.
And I stand by it
This whole thing seems to have gotten confused. As onlyflash944 had mentioned chromoly for a light $$$ cage, which "
" So I veered completely off topic to say that chromoly really isn't a good idea... Ect...
I apologize for pulling this thread so off topic.
Random Hero
Re: Recent Cage
« Reply #31 on: March 28, 2009, 10:50:57 PM »
 I welded the a's to the halo before i welded the halo to the hoop.
Re: Recent Cage
« Reply #32 on: March 28, 2009, 11:08:14 PM »
Works good with schedule 40 pipe. Not much else.
enikolayev
Re: Recent Cage
« Reply #33 on: May 01, 2009, 01:19:34 AM »
I was just curious about the dash. Are you going to notch the stock one?
Re: Recent Cage
« Reply #34 on: May 01, 2009, 11:32:21 AM »
If you do notch the dash can get a little write-up about I'm interested in this cage. :yes:
enikolayev
Re: Recent Cage
« Reply #35 on: May 01, 2009, 03:11:50 PM »
I'm thinking of a cage as well so this is good info.
Toysrme
Re: Recent Cage
« Reply #36 on: May 01, 2009, 06:28:10 PM »
looks good.
things to know about welding CM.
er70s-2 has not been the standard filler for it for years, tho people keep using it. use er80s-2 or s-6.
buy some temp-sticks and either preheat AND post heat all your joints to 300-400*F. normally you hear people talking about doing it only for over .120" thick wall. remember that the effective thickness in some welds will may make your welds beyond this thickness.
doesn't take long to tig-weld them, but it goes MUCH faster if you tack weld it with wire or stick. assuming you have an oxy-fuel torch, it takes very little time to pre-& post heat them. adds an extra two to each applicable weld.
ive read on the lincoln site some people use 310 or 312 filler. i wouldn't... can't find the mechanical properties anywhere online & that just adds one more type of rarely used filler to have laying around.
