Author Topic: CRX hydro/cable motor mount differences?  (Read 13143 times)
« on: November 30, 2009, 02:21:52 AM »
Well Jorsher has a set of EF B series mounts that are for a cable tranny. He is doing the hydro tranny with conversion and said he has to get a full set of mounts that are made for the hydro tranny and motor with hydro tranny. My question is: Is there a difference in the motor mounts them selves or just the tranny mount?  I tried looking it up, but all I find is people talking about the hydro conversion itself and not the differences in the mounts.
Re: CRX hydro/cable motor mount differences?
« Reply #1 on: November 30, 2009, 03:11:10 AM »
i believe its a different trans mount only.
« Reply #2 on: November 30, 2009, 03:29:10 AM »
That's what I was thinking as well. Would like to find out for sure as a new tranny mount would be a hella-va-lot cheaper than a whole new mount set.
« Reply #3 on: November 30, 2009, 03:50:57 AM »
Just a different trans mount
« Reply #4 on: November 30, 2009, 04:34:47 AM »
Good to know, should make Jorsher happy since will only have to fork over cash for one mount.
« Reply #5 on: November 30, 2009, 04:52:08 AM »
One motor mount, three tranny mounts, only one is correct,,,,,,,,,,
« Reply #6 on: November 30, 2009, 02:22:23 PM »
Damn it, for some reason I was thinking it was the other way around.
« Reply #7 on: November 30, 2009, 02:28:29 PM »
What swap mount set uses all 4 locations for a EF/ED chassis?
« Reply #8 on: November 30, 2009, 08:42:18 PM »
in ef's its all different except the engine side, eg's and ek's would only use a different tranny mount, but the rear mount is cool
« Reply #9 on: December 03, 2009, 04:40:24 PM »
Yeah, just gonna have to replace the set.
I thought something was up when the mount wouldn't go where I thought it should go.  The rear mount looked like it may work but I never fully mocked it up since the engine isn't completely put together.  Trans side mount definitely wouldn't work.
Oh well.
And no this set does not use all 4 mounts either.  Is there anything that does have full frontal action?
« Reply #10 on: December 03, 2009, 04:44:41 PM »
Oh well.
AS a general rule, no.  The front trans mount on ED/EF chassis cars is usually an additional option when you are using aftermarket mounts/  I really see no need for all 4 when you have aftermarket urethane mounts.  The drivetrain to chassis connection is incredibly solid with just the 3 mounts.
« Last Edit: December 03, 2009, 04:46:39 PM by snm95ls »
« Reply #11 on: December 03, 2009, 07:12:23 PM »
Yeah, wasn't going to go out of my way to have it, but figured it wouldn't hurt.
If I see one with it when I buy the new mounts, I'll grab it, otherwise, fuck it.
« Reply #12 on: December 04, 2009, 12:50:16 AM »
hcp use to have a front mount and so did place racing. both companies went belly up years ago.
« Reply #13 on: December 04, 2009, 01:04:37 AM »
Oh well.
Agreed. With my traction bar I only run inserts in the other 3 mounts and I don't have issues
