Author Topic: My snowblower wont start, whats cheaper  (Read 8326 times)
TTC
« on: December 09, 2009, 10:30:17 PM »
Fuck sakes, old gas from last season, in tank didnt add stabilizer. I'm not surprised it wont start, the fucker better not be gummed up after 8 months. I lll try new gas and a new plug, any other suggestions? I dont want to take apart the carb until i have to.
Which brings me to : Whats cheaper? new parts for blower or some antique farm equipment.  Who are better shovelers; beaners or nogs.
Re: My snowblower wont start, whats cheaper
« Reply #1 on: December 09, 2009, 10:33:12 PM »
on some of them, you can remove the bowl of the carb with 1 bolt, then use the straw on a can of carb spray to spray the main jet out. Pull the needle valve out and spray in there, then put it back however many turns out it was. Put bowl back on, fresh gas, and see if she starts
1slow91hf
« Reply #2 on: December 10, 2009, 12:12:27 AM »
stabilizer in the tank and new plug and fire it on starting fluid
fixed
Kain
« Reply #3 on: December 10, 2009, 12:28:47 AM »
be a man.
potatodude
« Reply #4 on: December 10, 2009, 11:32:00 PM »
« Reply #5 on: December 12, 2009, 01:34:22 AM »
« Reply #6 on: December 12, 2009, 02:11:16 AM »
Jesus God, am I ever glad people like you exist to keep my lawn mowed.
« Reply #7 on: December 12, 2009, 02:19:41 AM »
You may have him cornfused with D112CRZY whoi is an ACTUAL MEXICANT ffrom Yakivegas....  Where you cant tell the borderjumpers from the prairie niggers
« Reply #8 on: December 12, 2009, 02:21:33 AM »
Whereas no one ever gets you cornfuzed with a heterosexual, sir.  Just saying.
« Reply #9 on: December 12, 2009, 03:49:27 AM »
why do peole stick -vegas to the end of really shitty places?
« Reply #10 on: December 12, 2009, 05:39:21 AM »
The newer Arens have issues where a gas feed "bolt" in the carb gets a tiny particle stuck in it's miniature jet holes and starves for gas. Ask me how I know. Happens on quite a few small engines w/crappy gas filters.
The other thing is less than stellar motors (non-Hondas) will not start with old gas. It's not so much gum clogging stuff up, it's the reduction of octane & combustability you have to worry about. Low rpm preignition won't kill an engine, but it will refuse to start. One time I fucked with a customer's new robinson/subaru engine for 10 minutes, changed the gas on a whim, and it started in 2 pulls. "Oh the gas? It was only a year old". FYI gasoline has a shelf life of 2 weeks.
BTW check to see it has spark, obviously you should have changed the plug by now. That's the numebr 2 reason customers can't get shit started. Old plug, or left the choke on and never changed the black plug.
Cliffs:
1) check for spark
2) check for fuel (ether starting fluid)
3) make sure fuel & spark plug are fresh
2.slow_Jetta
« Reply #11 on: December 28, 2009, 09:23:29 PM »
my old ass snow blower had the same prob. now after a carb rebuild it runs like a champ.  :noel:
« Reply #12 on: December 28, 2009, 09:25:44 PM »
The carb should be easy as pie to clean and rebuild if needed. You sure the old gas is the problem? I've run year old gas before in a lawnmower and it was fine.
« Reply #13 on: December 28, 2009, 09:32:31 PM »
I was starting my car once a month for about 4 months with the same tank of gas in it...seemed fine.
Would really hate to dump a full tank of gas.
« Reply #14 on: December 28, 2009, 09:38:05 PM »
See if the carb has what looks like a fuel bowl with a plug on the bottom of it. If so, take it off, clean and work the solenoid that's on the bottom. They like to stick and not allow fuel to flow.
TTC
« Reply #15 on: December 28, 2009, 11:36:53 PM »
Yeh i got it, took the bowl off and fiddled with the jets. Put it back in and tuned it better than it came in the first place.
« Reply #16 on: December 28, 2009, 11:41:26 PM »
new plug and starting fluid
don't forget the yearly oil change, unless it consumes it
TTC
« Reply #17 on: December 28, 2009, 11:52:12 PM »
All last winter the damned thing wouldn't run without the choke on half. Hotter it got the more it didnt want to run.  Should be good now, im assuming it was running lean which is why it would stall less with choke on.
« Reply #18 on: December 29, 2009, 11:37:21 AM »
Build one of these:
Using what ever engine of your choice.
Could be used as a new engine dyno at the same time then you can tell 'Bisi how much snow and how it can throw instead of normal bhp @ x-rpms.  ;D
