Author Topic: stainless MIG wire, argon?  (Read 15526 times)
« on: December 11, 2009, 05:05:22 PM »
Would straight argon be okay for stainless wire on a MIG welder? Tack welding only.
I want to use my MIG for tack welding, since my cheapo TIG is scratch start & sucks for tacks. I don't want to use steel since it's for all stainless parts. I'm not concerned about penetration, looks, etc - it just has to hold until I can TIG over it. I wouldn't mind grinding
Re: stainless MIG wire, argon?
« Reply #1 on: December 11, 2009, 05:53:18 PM »
Yes.
« Reply #2 on: December 11, 2009, 06:05:52 PM »
One more question, should I use .023"/.025" or .035" wire? It would be mostly for sch10 fittings.
« Reply #3 on: December 11, 2009, 06:10:16 PM »
.023/.025
« Reply #4 on: December 11, 2009, 11:59:16 PM »
pretty much the smaller the wire the smaller the tack is gonna be. just watch out every time ive tig'd over a mig tack it allways crackles and pops, not sure if theres inclusions or something causing it but grinding as much of the mig away as possible helps.
« Reply #5 on: December 12, 2009, 10:56:08 AM »
where do you find stainless mig wire? i have looked and never seen it
« Reply #6 on: December 12, 2009, 01:42:35 PM »
Every welding supply store ever. You have not looked that close obviously.
« Reply #7 on: December 12, 2009, 01:49:38 PM »
no actual welding supply stores around here. home depot and tractor supply are about all i have
« Reply #8 on: December 12, 2009, 01:57:30 PM »
Might have to buy it online then.
« Reply #9 on: December 12, 2009, 02:34:33 PM »
I have a roll of it that im never going to use again, but shipping to you probably would be spendy since ur in Canaduuuhhhh  :-\
« Reply #10 on: December 12, 2009, 05:36:40 PM »
I'd guess it's from not having shielding gas for the initial arc? I don't care about grinding it away (I'd do that either way), I'm mostly concerned about rust & color.
Hey 88dx, lmk what you'd want for it and I'll probably buy the spool. I've only seen big spools of it on ebay and local, unless I special order it.
« Reply #11 on: December 12, 2009, 06:31:32 PM »
My mig welder let's me run the gas before the arc. I don't know if it was planned or not, but I can pull the trigger a little bit and get just gas. I do that to put out fires when welding weird things that catch on fire
