Author Topic: IT HELP  (Read 13630 times)
sfa22r
IT HELP
« on: January 01, 2010, 08:05:31 PM »
I need a program that lets me recover corrupted files from a Windows .bkf file.  I keep getting the "there are inconsistencies blahblahblah" error when I try to put the file back on another hard drive.  HALP
Re: IT HELP
« Reply #1 on: January 01, 2010, 08:45:37 PM »
http://www.fpns.net/willy/ntbkup.exe
Give that a shot. Be prepared for it to take a while.
Hopefully the corruption isn't from bad sectors on the HD.
http://www.fpns.net/willy/msbackup.htm#DWLD
Read there for help on running it.
This one might work as well:
http://www.fpns.net/willy/msqic.exe
« Last Edit: January 01, 2010, 08:49:17 PM by Ntrain2k »
Re: IT HELP
« Reply #2 on: January 01, 2010, 09:01:24 PM »
Look below.
« Last Edit: January 01, 2010, 09:56:19 PM by Ntrain2k »
sfa22r
Re: IT HELP
« Reply #3 on: January 01, 2010, 09:06:58 PM »
Maybe more explanation=more help.
I had a laptop hard drive.  It took a shit.  I pulled a backup file off of it that is 46gig.  Now, got a new hard drive, but when I go to used the Windows Backup Restore shit, it comes up with the inconsistency on the disk or w/e.  I need a way to either fix that, or skip over it and keep restoring the rest of the file to the HD, otherwise, it stops at like 4gigs in.  No bueno
sfa22r
Re: IT HELP
« Reply #4 on: January 01, 2010, 09:16:25 PM »
Fuck.  I get to play games with rapidshare till it lets me download
Re: IT HELP
« Reply #5 on: January 01, 2010, 09:17:04 PM »
It made me wait 67 seconds.   :noel:
sfa22r
Re: IT HELP
« Reply #6 on: January 01, 2010, 09:17:49 PM »
Gay.  Damnit.  How hard is it to crack the software?  Would like to have this shit done and transferred over by tomorrow lol
Re: IT HELP
« Reply #7 on: January 01, 2010, 09:28:18 PM »
Delete that one, someone stuck a virus in it.
Digging for a clean one now.
I have 2 others coming in. I'll scan them then let you know.
Ok, got a clean one. Uploading it to a site where you can get it. It's precracked already as well.
« Last Edit: January 01, 2010, 09:42:49 PM by Ntrain2k »
Kain
Re: IT HELP
« Reply #8 on: January 01, 2010, 10:04:36 PM »
unfortunately when you back up a backup of the file and it happens to be corrupted, you lose a large portion of data. the best way to rebuild it is to use some proprietary software that is designed and built in linux. im sorry i couldnt help further.
sfa22r
Re: IT HELP
« Reply #9 on: January 01, 2010, 10:10:56 PM »
I don't want to back up the back up, I want to make it go onto the new hard drive so I can use that hard drive :evil:
sfa22r
Re: IT HELP
« Reply #10 on: January 01, 2010, 10:13:59 PM »
Kain
Re: IT HELP
« Reply #11 on: January 01, 2010, 10:34:05 PM »
unfortunately you did not read what i posted.
give the EXACT error that is posted.
sfa22r
Re: IT HELP
« Reply #12 on: January 01, 2010, 10:42:09 PM »
When I go to use the built in Windows app to put the .bfk file onto the other hard drive, I get this...
Backup Utility: An inconsistency was encountered on the requested media
That shit, and then it just halts the install.  Fack.
sfa22r
Re: IT HELP
« Reply #13 on: January 01, 2010, 10:52:56 PM »
Here is the clean one:
http://www.filedropper.com/fo-er62
Okay, it is finding the files on the old drive.  What should I do from there once it finds em
Re: IT HELP
« Reply #14 on: January 01, 2010, 11:11:14 PM »
It should give you the option to save them to a new location.
Look for destination.
Has it made it further then you did before yet?
sfa22r
Re: IT HELP
« Reply #15 on: January 01, 2010, 11:13:51 PM »
Yeah.  So then just put the files somewhere.  And then copy them over to the new hard drive?  Should I put windows on the new HD first?
Re: IT HELP
« Reply #16 on: January 01, 2010, 11:19:00 PM »
I'd get them off of that drive, first thing and onto another one.
Once they are off of it, I think there is a set of tools with the program that can thoroughly check and test the old drive. It might still be usable once it's had a full format and the bad clusters have been marked.
Here is the guide to the program:
http://www.ontrackdatarecovery.com/library/erguide_en.pdf
Re: IT HELP
« Reply #17 on: January 01, 2010, 11:20:28 PM »
Let me know how it ends up for ya.
BTW, that's a $500 program.
« Last Edit: January 01, 2010, 11:25:33 PM by Ntrain2k »
sfa22r
Re: IT HELP
« Reply #18 on: January 01, 2010, 11:29:14 PM »
Nice man.  Thanks!
Kain
Re: IT HELP
« Reply #19 on: January 01, 2010, 11:32:36 PM »
yah on track is mentioned in my data recovery class.
Re: IT HELP
« Reply #20 on: January 02, 2010, 12:53:07 PM »
Bump for updates.
Re: IT HELP
« Reply #21 on: January 02, 2010, 12:57:36 PM »
ITT Henry Henries himself.
Well played, sir!
sfa22r
Re: IT HELP
« Reply #22 on: January 02, 2010, 01:38:06 PM »
Bump for updates.
Shit kept shutting down 24gig into the restore, so I'm trying it again in safe mode
Re: IT HELP
« Reply #23 on: January 02, 2010, 01:40:57 PM »
Disable everything while it is running.
AV, etc.
With how it digs to recover, most AV programs with hueristic logic flag it and go apeshit.
sfa22r
Re: IT HELP
« Reply #24 on: January 02, 2010, 01:49:26 PM »
Everything is disabled now :)  Hope this works
sfa22r
Re: IT HELP
« Reply #25 on: January 02, 2010, 06:00:07 PM »
Okay, that shit still didn't work.  I have a .bkf file I need to repair, and that will simplify everything.  There are .bkf repair programs, but I can't seem to find a torrent for a full version.  HALP?
sfa22r
Re: IT HELP
« Reply #26 on: January 02, 2010, 06:57:31 PM »
When I go to open the exe, nothing happens....  help?
Re: IT HELP
« Reply #27 on: January 02, 2010, 07:18:51 PM »
Open the on track program again, go to .zip repair. browse to the .bkf file, on the bottom dropdown, select all files. Select the .bkf file and go.
When it is done, open the newly created file and see if it works. If it still don;t, run it on the new file.
Usually works.
sfa22r
Re: IT HELP
« Reply #28 on: January 02, 2010, 07:25:11 PM »
Usually works.
It shuts itself off :(  I'll run it and take a screen shot real quick...
sfa22r
Re: IT HELP
« Reply #29 on: January 02, 2010, 07:28:34 PM »
