Author Topic: Copper charge pipes  (Read 19974 times)
gooseman
Copper charge pipes
« on: January 06, 2010, 12:26:06 AM »
http://autospeed.com/A_110860/cms/article.html
Ran across this in my search for intercooler piping. This would be sweet since I have access to a torch and solder/flux, but not a welder.
Antone here done this?
Re: Copper charge pipes
« Reply #1 on: January 06, 2010, 12:45:04 AM »
Copper is usually more expensive than aluminum (depends how you acquired it) :evil:
Copper is a great conductor of heat even more efficient than aluminum.
Besides everybody know PVC intercooler piping is where is at.  ;D
BTW the article on the site are entertaining. Some cool ideas on there. :yes:
« Reply #2 on: January 06, 2010, 01:24:10 AM »
i haven't, but there is no reason you can't if you have the materials and tools to do it
7808
« Reply #3 on: January 06, 2010, 02:25:01 AM »
if the stuff cheaper then i thought, and i could map gas solder it, id try it
« Reply #4 on: January 06, 2010, 02:27:27 AM »
buy a rope and tress are free
« Reply #5 on: January 06, 2010, 05:19:03 AM »
copper is NOT cheap......why do you think all the hoodrats are breaking into vacant homes and ripping out the piping......but I've no problems sweating the connections.
« Reply #6 on: January 06, 2010, 09:56:31 AM »
Damn right, thats what I used on my first kit, I had painted it flat black! :noel:
« Reply #7 on: January 06, 2010, 10:04:57 AM »
Yeah if you look at Specter Performance intake piping kits in parts stores that cater to the ricers.
They make a chrome painted piping kit that locks together.  ;D
Already main stream sort of.
« Reply #8 on: January 06, 2010, 06:19:18 PM »
Looks cool on the surface, but it's not needed. I run steel pipes that are painted and my AIT's post IC are 4-8*F over ambient when in boost, cause the IC isn't 100% effective, maybe 90% effective. My hotside IC pipe might drop 5*F from the charge before it goes in the intercooler. But even if I put a copper one that dropped 20*F from it, once the IC takes away 90% of the temp delta, the result would be 3-7*F above ambient probably. Negligable.
7808
« Reply #9 on: January 06, 2010, 07:00:48 PM »
i thought maybe with years of stolen copper being recycled + the fact newer houses use less copper and more snap together plastics plumbing shit, maybe the prices took a dump?
« Reply #10 on: January 06, 2010, 07:04:46 PM »
prices took a dump when china had the olympics.  they shut down industry for like 3 weeks to clean the air up and thus every bit of scrap that goes to the slant eyes got backed up in the states.  then theres this recession thingy
« Reply #11 on: January 06, 2010, 10:51:36 PM »
damn, i was just thinking abou this the other day. not that i planned to do it, but it seemed like a very easy way to make charge pipes.
« Reply #12 on: January 06, 2010, 11:02:08 PM »
it is, if you can find a cheap source of copper.
« Reply #13 on: January 06, 2010, 11:09:53 PM »
yea, cost was the big factor in why i wouldnt do it.
bigwig
« Reply #14 on: January 07, 2010, 12:05:09 AM »
High thermal conductivity is not always good.  If its hotter under the hood than it is in the intake pipes, I see no reason you'd want to use aluminum/copper.  On the hot side, in theory, always use a material with a high thermal conductivity.  On the cold side, it's a questionable choice.  I'd personally use whatever is cheapest.
gooseman
« Reply #15 on: January 09, 2010, 01:28:34 AM »
Scratch it. I got some pipe from a buddy. I will use PVC for what ever pipe I don't have.
slappynuts
« Reply #16 on: January 09, 2010, 07:12:17 PM »
I bet you could use alumiweld and a tailpipe expander to sweat aluminum charge pipes. Whos going to be the first to try it?
NoPistons!
« Reply #17 on: January 12, 2010, 01:49:19 AM »
I thought about using baby seal foreskin for couplers and hollowed out whale bones for charge piping.
Mink on the seats, snake skin on the wheel.
Pimp.
I couldn't see any reason to use copper charge piping when you can use brake kleen cans......
